head gasket? smoking engine
Old Apr 20, 2005 | 10:51 AM
95strfytr's Avatar
Default head gasket? smoking engine
How do you know if your head gasket is bad even if the compression is good? d16y7 smokes white at wot and burns oil.
Old Apr 20, 2005 | 11:02 AM
DJ_SaNdOz's Avatar
Default Re: head gasket? smoking engine (95strfytr)
smoking at WOT doesn't necessarily mean a HG issue. If you are experiencing no coolant loss, but some oil loss it could also be the rings.
Old Apr 20, 2005 | 11:04 AM
95strfytr's Avatar
Default Re: head gasket? smoking engine (DJ_SaNdOz)
i did the compression test and the cylinders were all around 170.
Old Apr 20, 2005 | 11:05 AM
EVIL Hx Coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95strfytr &raquo;</TD></TR><TR><TD CLASS="quote">i did the compression test and the cylinders were all around 170.</TD></TR></TABLE>
White smoke is what you're looking for when you're dealing with the headgasket.
The only way to be sure though, is to do a leakdown test.
Old Apr 20, 2005 | 11:08 AM
95strfytr's Avatar
Default Re: head gasket? smoking engine (EVIL Hx Coupe)
I pulled the pcv valve and I smell fuel. It also has lost a lot of power. The engine has 80000 on it. The valves are out of adjustment as well, but not too bad.
Old Apr 20, 2005 | 11:10 AM
95strfytr's Avatar
I'm about to put a y8 head on it. But i want ot make sure that it's gasket before i proceed. How do you do a leakdown test?
88 EF Hatch
Jul 11, 2009 09:50 PM
TegraD
Nov 9, 2008 01:49 PM
quick87crxsi
Nov 26, 2006 05:42 PM
dutchman5
Aug 5, 2004 02:58 PM
EARLdaSQUIRREL
10
Aug 8, 2003 02:43 PM
