Competition Engineering Traction Bar P/N 9300
Selling a complete competition engineering traction bar part # 9300
taken from http://www.spiderautomotive.com (no affiliation with this sale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Civic traction bars by Competition Engineering. The Civic traction bar system by Competition Engineering comes complete with crossmember and adjustable brackets for easy installation, chrome moly radius rods and left and right hand 1/2" rod ends for simple on car adjustment of preload.Includes all mounting hardware and easy to follow instructions. This bolt on Civic traction bar system mounts to existing locations for provide a solid connection between the chassis and lower suspension arm, no drilling or welding require. Solid front suspension eliminates wheel hop and tire shake, transmits forces into chassis and keeps weight over the front end to greatly improve traction and 60 foot times. Three hole setting allows you to tune the suspension and adjust weight transfer for your particular ride height setting, ideal when using a lowering kit. Controls driveline loading to minimize wear and breakge. Designed for racing, but can be used on the street if you remove the radius rods. NOTE: Will not fit the CRX.
Honda Civic traction bars Competition Engineering Comp Eng 9300</TD></TR></TABLE>
Traction bar is located in Brisbane. $250 Firm
Thanks
Alex
crispikreme@yahoo.com
AIM: CrispiKreme
Thanks
Alex
AIM: CrispiKreme
portenio78
Jul 6, 2010 06:44 PM
