battery in hatch.
Old Apr 20, 2005 | 10:15 AM
S13 slide's Avatar
Default battery in hatch.
i picked up a eg with an unfinished b18b swap. the battery is in the trunk and the positive battery wire goes into the engine bay but is not connected to anything. the stock battery wire terminal peice is not there any more. when you put the battery in the hatch where do you wire the positive cable to? thank you
Old Apr 21, 2005 | 11:56 AM
S13 slide's Avatar
Default Re: battery in hatch. (S13 slide)
Old Apr 21, 2005 | 12:27 PM
ace42004's Avatar
u get a distrubtor thingy from a audio store for running two amps..u hook the one side up to the end of the wire coming from the battery. Then the other side of the distributor block should have two holes..use one to run one wire to the starter and the other to the engine fuse box...here is a pix to what im talkin about..hope this helps
http://www.millionbuy.com/scopdm48x2.html
Old Apr 21, 2005 | 12:30 PM
S13 slide's Avatar
Default Re: battery in hatch. (ace42004)
Thank you
jc95148
11
Dec 21, 2012 08:53 AM
91EF919
Apr 6, 2009 08:27 PM
EFz6er
Aug 4, 2005 10:29 AM
Keith P
Mar 22, 2004 12:59 AM
customx_
37
Jan 28, 2002 12:03 PM
