Question on 99ex
I'm not sure if you can, but it would proably be in the manual if you could. I suppose if it can't be programmed in, you could cut the signal wire from the brain.
Hey h22 read before you reply next time. We are DISARMING the stock system to INSTALL a new system, which will be the next step DUH right back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by surrealcivic17 »</TD></TR><TR><TD CLASS="quote">Hey h22 read before you reply next time. We are DISARMING the stock system to INSTALL a new system, which will be the next step DUH right back</TD></TR></TABLE>
what are u talking about.. u mention nothing about installing a new alarm ...
but anyways... if u are installing a new alarm, then it will be in the manual... basically programmable from the valet swtich and buttons on the key fob
Wait, so are you trying to stop it from beeping with the stock alarm, or are you trying to disable the stock alarm to install an aftermarket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicVX »</TD></TR><TR><TD CLASS="quote">i think press the option button and the lock unlock. look at the back of the remote it should say. </TD></TR></TABLE>
Stock honda alarm only has a lock, unlock and panic button.
Lemme try to clear it up. My friend wants to disable the horn when the car is locked and unlocked because he wants a real alarm system to be installed at a later time. My question was how do I go about uninstalling the stock horn chirp. There is a wire that can be cut?
If you cut the wire that makes the horn chirp when you arm the system, then the alarm itself will have no horn to sound through.
So if thats what you're trying to accomplish, then find the security control unit and clip the gray wire at pin 18.
In other words, you can't have one without the other.
Thanks for your help HT, im confused also as to what my friend with his ex really wants to do, and Im not sure how that stupid horn thing works and what it does because it is not my car. So yeah whatever, my friend just wants a chirping system to sound cool, he doesnt even have anything in the car to steal so screw this gay project
stylin retro
Audio / Security / Video
Jun 20, 2004 11:15 PM
