timing belt??
Old Apr 20, 2005 | 09:43 AM
jbj-kustomz's Avatar
Default timing belt??
ive heard a few opinions on when to replace your timing belt on a honda motor. 100k sound right?? is this necessary or just recommended?
Old Apr 20, 2005 | 10:31 AM
MrHeeltoe's Avatar
Default Re: timing belt?? (jbj-kustomz)
Factory recommends 60-90K.....
Old Apr 20, 2005 | 10:33 AM
mr.beeks's Avatar
Default Re: timing belt?? (MrHeeltoe)
I replaced timming belt somewhere after 115k
so 100k sounds like a good timeline...
Old Apr 20, 2005 | 11:24 AM
VINtegra90's Avatar
Default Re: timing belt?? (mr.beeks)
get that **** done... its worth it
Old Apr 20, 2005 | 01:43 PM
csprague's Avatar
My manual say 105k, I will probably do it around 75k or so.
Old Apr 20, 2005 | 01:57 PM
kchungb17a's Avatar
Default Re: timing belt?? (csprague)
Originally, the factory recommended interval is 90k, but with a little R&D and the overall corporate money machine trying to make you feel like you get more out of your hard earned dollar, they bumped it to 105k. I wouldn't drive it a foot over 105k if that's when you decide to do it. I've seen them break as early as 120k and as late as 210k. It's just a crap shoot there. And hell yeah it's needed. If it breaks on you and you have a non-clearance engine (valves and pistons make contact when pistons are at TDC and valves are full open) like all B, D, H, F, K series engines, you are going to be paying for a lot more than just a new timing belt!
Old Apr 20, 2005 | 02:05 PM
sinister357's Avatar
Default Re: timing belt?? (kchungb17a)
from what i have experienced, the d series, as far as the z6 goes, is "NOT" an interference motor. i had my belt broken before and all is well with a new belt. while the motor was down, i cranked it plenty and played with the cam gear spinning it all over and nothing happened. thats just my personal experience.
Old Apr 20, 2005 | 02:35 PM
thanks for the info guys, i ordered my timing belt earlier today!!!
Old Apr 20, 2005 | 03:52 PM
esp's Avatar
esp
Default Re: (jbj-kustomz)
yea its definatly worth having it done, or doing it yourself. its better then having to get a new motor down the road.
Old Apr 20, 2005 | 04:24 PM
Cabby89's Avatar
I changed mine on my B18 at about 180k. That was only after it finally broke. No bent valves or anything. Its also supposed to be an interefence motor and I got lucky.
Safety_Driver
Aug 30, 2011 05:12 PM
Killtodie
Honda Civic (2001 - 2005)
18
Apr 13, 2007 02:00 PM
Zeppelin340
Mar 1, 2006 06:18 AM
00siALLmotor
Acura TL, RL & ZDX
Jan 30, 2005 09:31 PM
jimby452
Dec 8, 2004 03:43 PM
