b16b head onto 2000 si ecu?
Hey instead of getting a ctr valve train why dont i just get the entire head already assembled? My valve guides are shot and im blowing blue smoke pretty bad. my compression is fine and i did cylinder leakdown so im sure thats it. So i was thinking of just finding a b16b head and putting it on my car. My question is will i have to change my ecu? or maybe get it rechipped? Thanks.
BTW im pretty sure it will bolt rigth up am i wrong?
It'll bolt right up. If you're wanting to take advantage of the higher revs and redline, you'll need a chipped ecu/hondata, aem ems, uberdata....yougetthepoint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-si-2000 »</TD></TR><TR><TD CLASS="quote">Will 9,000rpm be safe on my stock rods/pistons? </TD></TR></TABLE>
I think the stock valves would have more of a isue with 9,000rpm than the pistons but your different head you should be fine. i could be wrong though.
94lsvtec
Jul 19, 2008 06:56 PM
agrabau
11
May 21, 2004 04:44 PM
