what happens when a rod is put on backward
Old Apr 20, 2005 | 08:24 AM
97BLACKCIVIC's Avatar
Default what happens when a rod is put on backward
I took my Gsr rods to a machine shop to have b16 pistons pressed on. Well after installing everything and running the motor, i started hearing a knocking noise. took everything back apart and the rod that was backward was the one that had a bad bearing. Did it spin because of it being backward, or could it be something else. And if it does matter about having it the right way, y would it spin a bearing within 30 mins. Im pretty well mechanically inclined but i need some help on this so if you can help me out thanks.
Old Apr 20, 2005 | 08:27 AM
Luserkid's Avatar
Default Re: what happens when a rod is put on backward (97BLACKCIVIC)
Thats pretty weird, i never heard of that. I would think it doesnt matter as long as the pistons are the right way, but then again i could be wrong.
Usually the way knocking (spun rod) happens is when you have no oil in the car and rev it or its a bad install.
Old Apr 20, 2005 | 08:33 AM
i thought it was too but you know how that goes, that one thing can make everything go wrong. but thats y im askin cuz i wanna make sure
Old Apr 20, 2005 | 09:04 AM
Luserkid's Avatar
oh i totally understand what you mean. Good luck with it, heres a free bump for you.
Old Apr 20, 2005 | 09:48 AM
Jon at Titan's Avatar
heres a bump for you im dying to find out as well
Old Apr 20, 2005 | 09:55 AM
AutoXer's Avatar
Default Re: (El_buster)
Bump... I thought the rods were symetrical... I guess I could be wrong.
Did you use break in grease?
Old Apr 21, 2005 | 05:44 PM
Default Re: (EX_AutoXer)
i used assembly lube on the front side, and i did not touch the face of the bearing on the front or back. The only thing i can think of is my friend didn't torque the arp rod bolts down to spec. Everyone that i talk to about the rod being backward says that it should make a difference because everything is balanced individually, so when they put it together its all balanced. Thats what ive been told anyways.
1320london
Engine Machining & Assembly
19
Mar 2, 2017 05:10 PM
jdmvtec28
Apr 14, 2005 08:13 PM
P1mpSlap
Jul 9, 2003 11:46 AM
VanHonda
Jun 21, 2003 02:25 PM
B20zvtecek
Oct 28, 2002 07:11 AM
