Pistons skirts scarred. Are these salvage able?
Old Apr 20, 2005 | 08:01 AM
275Performance's Avatar
Default Pistons skirts scarred. Are these salvage able?
I just took my motor apart last night. Cylinder walls and pistons are scarred.
Before taking the motor apart, I was planning to sell these to go to a higher CR.
But now I am unsure if thats possible.
There are the worst two. Intake sides of cylinder 2 & 3.
You can't really feel the marks. I am going to try and take some brighter & clearer photos later tonight.
Any intial thoughts if these are reusable/sellable?
Endyn Rollerwave Crvtec 84.5mm roughly 9.2:1 in the motor setup.
Modified by 275Performance at 10:40 AM 4/30/2005
Old Apr 20, 2005 | 08:12 AM
adictionbass's Avatar
Default Re: Pistons skirts scarred. Are these salvage able? (275Performance)
guessing thats from clearances that were too tight and piston expansion?
Someone knowledgable chime in here
Old Apr 20, 2005 | 08:29 AM
Default Re: Pistons skirts scarred. Are these salvage able? (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">guessing thats from clearances that were too tight and piston expansion?
Someone knowledgable chime in here </TD></TR></TABLE>
The piston to wall clearence was fine I think. When GE did the sleeving, they bored it with the pistons there and with spec sheet from Endyn. I think I F'd up on the rings and they are what caused the scarring.
I was tearing this down to rebuild it cause I wasn't sure on it, its the first motor I've built, but I didn't expect to find that. Oh well. 85mm next
Old Apr 20, 2005 | 08:33 AM
turbosi03's Avatar
leanning out will cause that. the extra heat will make the pistons expand more then the clearance will allow.
I wouldn't think you can sell them because who wants to put a motor together with used pistons...? but if you can find someone then great
Old Apr 20, 2005 | 08:38 AM
Default Re: Pistons skirts scarred. Are these salvage able? (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">leanning out will cause that. the extra heat will make the pistons expand more then the clearance will allow.
I wouldn't think you can sell them because who wants to put a motor together with used pistons...? but if you can find someone then great</TD></TR></TABLE>
I've known a few people to do that, because price difference or better than OEM during a rebuild etc.
Old Apr 20, 2005 | 09:01 AM
Suprdave's Avatar
Get the Skirts Coated...and then reuse them. It will build back up the clearance...
Old Apr 20, 2005 | 09:12 AM
D-tuned's Avatar
Default Re: Pistons skirts scarred. Are these salvage able? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Get the Skirts Coated...and then reuse them. It will build back up the clearance...
Old Apr 20, 2005 | 09:15 AM
Damn. I never thought of that. Thanks for the info.
I was planning to remove these and go to a much higher CR.
Anyone interested in these?
Old Apr 20, 2005 | 10:09 AM
turbosi03's Avatar
maybe check to make sure they are still round...
Old Apr 24, 2005 | 09:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">maybe check to make sure they are still round...</TD></TR></TABLE>
It'll be a few days. Waiting on my new micrometer to get here.
Old May 5, 2005 | 01:39 PM
Mic'd the skirts and all came back 84.5
Selling them for $185 shipped.
https://honda-tech.com/zerothread?id=1232322
I also have the sleeved b20b these came from forsale cheap too.
turbohf
Apr 8, 2006 08:33 PM
LudeyKrus
Mar 3, 2005 07:04 PM
turbociv
Feb 13, 2005 04:51 AM
spettinger
Jan 26, 2003 09:01 AM
turbo Si
Jun 28, 2002 12:00 PM
