converting to OBD1 , parts??
Old Apr 20, 2005 | 07:44 AM
Turbo_Mike's Avatar
Default converting to OBD1 , parts??
After realizing my pr3 can't be boosted on, i decided to go obd1....starting pricing/buying stuff out last night, and didn't realize it would be soo much...
Just wondering how much you guys typically pay for these parts and which to get?
Chipped p28
obd1 Distributor (which to get?)
o2 sensor (best place to get one?)
conversion harnesses ($150 for dizzy plug and ecu harness )
Also, exactly what dizzy's can be used...obviously a obd1 dohc vtec would be best... What does it take to use an LS dizzy? Can a sohc one be used??
Anybody buy a used o2 sensor online or ebay or anything?
Old Apr 20, 2005 | 08:21 AM
drdisco69's Avatar
Default Re: converting to OBD1 , parts?? (razor ron)
You can always use a PM6 from the Si. It can run VTEC and boost with some chipping.
If you're going to convert to OBD1, you can convert most any of the ECUs to the equivalent of a P28 with just a few parts. That might make the search go a little easier.
You can get any OBD1 or OBD2 distributor, but as you know, the non-vtec ones will take a little cutting, so get a vtec one if you can. Integra GS-Rs and 99-00 Civic Si work well for this.
Try autozone or something like that for the O2 sensor. The dealer wants an arm and a leg for one, you might imagine. You can try used, but remember, that person is selling it for a reason.
I'm making my own conversion harness, but to buy a pre-made one saves an incredible headache if you don't enjoy soldering and shrink wrapping.
Old Apr 20, 2005 | 08:36 AM
DaX's Avatar
DaX
Loved
Community Favorite
P28 - You can probably find a P06 for a better price [92-95 Civic DX]. RaverMotorSports can add VTEC, IAB, and TONS of other stuff to a P06 to make it exactly like a P28 or better. RaVer can also handle your socketing...but so can a bunch of other places and/or people on this board.
OBD-1 Distributor - DistributorKing
o2 Sensor - oxygensensors.com
Conversion Harness - Boomslang
Old Apr 20, 2005 | 08:42 AM
drdisco69's Avatar
Default Re: converting to OBD1 , parts?? (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">but so can a bunch of other places and/or people on this board.</TD></TR></TABLE>
I didn't want to pimp myself out like that...
Old Apr 20, 2005 | 09:06 AM
Turbo_Mike's Avatar
Default Re: converting to OBD1 , parts?? (drdisco69)
good info, thanks guys. I'll start looking into those sites. I ended up buying a chipped p28 w/ skunk2 program and datalogging capible for 157 shipped priority... i dont really have the time to find a p06 or the like and have it shipped and chipped, etc, but thats pretty cool they can do that
Old Apr 20, 2005 | 09:22 AM
DaX's Avatar
DaX
Loved
Community Favorite
$157 for a chipped P28 ain't bad! I'd ditch the "Skunk2" ROM though, and either run a real EMS or just cut jumper J1 in the ECU to run the stock program.
The "Skunk2" ROM is just going to make you have shitty gas mileage and lose power.
Old Apr 20, 2005 | 09:47 AM
NikoZai's Avatar
Default Re: (DaX)
1 stop shop - I even have cleaned and flow tested OBD1 njectors in this week.
http://www.rywire.com - Dizzy, O2, wiring conversion, JKOBD Jumper harnesses, subharnesses or run through your stock harness for a cleaner look.
Old Apr 20, 2005 | 10:02 AM
riceisnicenv's Avatar
Default Re: (NikoZai)
wow... so many business plugs in this thread. creator asked for it though lol
Old Apr 20, 2005 | 10:05 AM
CLICC916's Avatar
i'll assume u currently have an obd0 (first gen) b16? if you want a a perfect fit with no cutting, get a 92-93 gsr distributor. don't buy a used o2 sensor unless you know the person who's selling it to you. even then, i'd still suggest getting a new one from autozone (bosch) just to make sure. some people will tell you to buy from the factory, which is the best method, but damn, they sure are expensive ($200+ at honda compared to $100 at autozone for the bosch). i put the bosch in my setup, which was obd0 b16 but now obd1 b16... some people will tell you that the harness is really easy, but for my case, although the harness quality was good, i ended up cutting and soldering a lot of the wires to retrofit the way my obd0 harness was setup. it depends on whether or not your obd0 setup was jdm or usdm...if it was wired jdm, then i'd suggest reading some wire diagrams and rewire it yourself. if it was usdm, then you can save yourself some time by buying the obd1 jumper harness. the distributor is easy to cut and rewire also, but if you want to save time, then you can also buy that harness
Old Apr 20, 2005 | 10:27 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.rywire.com</TD></TR></TABLE>
They have excellent stuff.
Old Apr 20, 2005 | 10:42 AM
crx_88_si's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote"> just cut jumper J1 in the ECU to run the stock program.</TD></TR></TABLE>
BAD advise. lets not forget he's running a b16 and the p28 is for a z6
Old Apr 20, 2005 | 08:23 PM
Turbo_Mike's Avatar
Default Re: (crx_88_si)
yea, i wouldnt do that or use the skunk2, probably tune the car with uberdata
Old Apr 20, 2005 | 11:09 PM
Rywire's Avatar
Default Re: converting to OBD1 , parts?? (CLICC916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLICC916 &raquo;</TD></TR><TR><TD CLASS="quote"> some people will tell you to buy from the factory, which is the best method, but damn, they sure are expensive ($200+ at honda compared to $100 at autozone for the bosch). </TD></TR></TABLE>
LOL, we have factory honda 02's for cheaper than the POS Bosh ones
Also you need a td44u dizzy. Any obd1 b series works the same. 92-93/ 94-95 gsr, b16a del sol, exc...
Ryan
Old Apr 21, 2005 | 03:58 AM
Turbo_Mike's Avatar
Default Re: converting to OBD1 , parts?? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">
GSR OR ls?
Old Apr 21, 2005 | 05:01 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
BAD advise. lets not forget he's running a b16 and the p28 is for a z6 </TD></TR></TABLE>
Not that this would be ideal, but many of my friends run B16's on the stock P28 program with zero issues.
Old Apr 21, 2005 | 08:48 AM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by razor ron &raquo;</TD></TR><TR><TD CLASS="quote">GSR OR ls? </TD></TR></TABLE>
GSR only
Old Apr 21, 2005 | 01:08 PM
Turbo_Mike's Avatar
Does anybody make a plug and play harness for obd0 vtec -&gt; obd1???
I dont wanna pay $100 for a harness then still have to mess around with mad wires.
Old Apr 21, 2005 | 05:17 PM
Rywire's Avatar
OMG, you didnt go to http://www.rywire.com, did u?
Old Apr 21, 2005 | 07:11 PM
Turbo_Mike's Avatar
i don tget it...but yea i did.
All these harnesses seem to be obd0 -&gt; obd1 vtec swaps
I'm going obd0 vtec -&gt; obd1 vtec.... i dont wanna have to go in and hack up all my wiring because these conversion harnesse already have prefabbed jumpers or w/e?
Old Apr 22, 2005 | 11:44 PM
Rywire's Avatar
Are you SIR? If so I can have 1 made, no problem.
Ryan
Old Apr 23, 2005 | 06:52 AM
Turbo_Mike's Avatar
no its a usdm dx, just have the b16 all wired up
Old Apr 23, 2005 | 09:59 AM
Rywire's Avatar
Ok, and you dont want to have to remove the couple extra wires that you had to pin into the ecu? Chit, just cut them, you dont even have to depin. I dont see what the big deal is.
Ryan
marauder228vw
Dec 19, 2011 06:35 AM
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
Bsixteen_CRX
Oct 10, 2007 04:43 PM
phenomB16
Jul 29, 2006 01:48 AM
EFing8
11
Dec 15, 2002 09:08 AM
