Running Rich, need help
Old Apr 20, 2005 | 07:43 AM
B18B EK's Avatar
Default Running Rich, need help
I rebuilt my engine, had it sleeved and bored to a 2.0l and forged rods and pistons. Regardless, now the car runs really rich and it falls on it's face when ever you rev it. I had 450's in it and I took them out and put the stock ones in. Still rich. I do have uberdata, but I have it set to stock and my friend tried the ecu on his car and it worked fine. This is a b18b, and no codes are thrown. I have also switched the fpr and the map sensor and nothing changed. Any input would be appreciated.
Old Apr 26, 2005 | 10:43 AM
B18B EK's Avatar
Default Re: Running Rich, need help (B18B EK)
bump
Old Apr 26, 2005 | 11:56 AM
devnull's Avatar
Dyno Tune it. or wide band tune it. It's all you can do. Are you chipped? Which one? Try configuring a stock bin to run 240's with 2.0l engine. Then go from there.
Old Apr 27, 2005 | 11:28 AM
B18B EK's Avatar
Default Re: (qi_doy)
It won't run right with everything stock. It should be running a little lean with a stock ls ecu. Could the throttle position sensor mess this up if it's bad. Maybe it's reading it's at full throttle.
Corksil
23
Jul 14, 2011 05:59 PM
ox_22
Jun 30, 2009 09:18 PM
stealthhatch
Feb 9, 2005 09:24 PM
B18B EK
Feb 7, 2005 09:29 PM
VTgringo
Aug 17, 2003 07:21 PM
