water pump & oil pump-should it be changed?
Old Apr 20, 2005 | 07:31 AM
jsnm's Avatar
Default water pump & oil pump-should it be changed?
doing an engine re-build,is the water pump and oil pump change necassary,or would the old ones suffice?they have about 110k miles on them and worked fine.thanks
Old Apr 20, 2005 | 07:44 AM
hanson said's Avatar
Default Re: water pump & oil pump-should it be changed? (jsnm)
better safe than sorry. they aren't too expensive, and it's sooo much easier to replace them when the motor is out of the car. i would definitely change them out for new dealer bought pumps.
Old Apr 20, 2005 | 08:32 AM
Honda Hick's Avatar
I would change the water pump because the seals can go in them and they can leak. You should usually change it when you do a timing belt. The oil pump can be checked to see if it is within tolerance. Get out your Helms manual and check it. I didn't get a new oil pump when I rebuilt my B18A at 175k and it had great oil pressure when I sold it at 251k miles.
boostedb18kid
Nov 10, 2007 02:10 PM
idriveadelsol7
25
Dec 9, 2005 08:47 PM
bankhead83
Jun 9, 2005 05:41 PM
Malgerus
Jan 11, 2003 04:33 AM
