D16y8-low oil pressure?
Old Apr 20, 2005 | 03:45 AM
civic-4-ges's Avatar
Default D16y8-low oil pressure?
I usually run around 75 psi at around 4K rpm
last month this dropped down to 60-65
Usually this is a sign of rod bearings in the y8 (past experience)
However I replaced the rod bearings, and still am getting this low reading, directly afterwards
Could this be a sign of even bigger problems?
Old Apr 20, 2005 | 04:30 AM
LSVTEC 91 Civic's Avatar
Banned
You getting 50psi at 3k?
What's your idle PSI?
Old Apr 20, 2005 | 04:57 AM
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">You getting 50psi at 3k?
What's your idle PSI?</TD></TR></TABLE>
Around 25....which is not low
I guess I am used to higher pressures...and not I may be getting "normal" pressure
Old Apr 20, 2005 | 07:11 AM
99hatch's Avatar
Default Re: (civic-4-ges)
would a leak cause this problem? my car was running low psi and i changed my oil pan gasket recently and now its fine.
Old Apr 20, 2005 | 08:03 AM
Crazydave's Avatar
Default Re: (99hatch)
have you changed the oil lately, are you using the same grade,
also how hot was the oil?
Old Apr 20, 2005 | 08:07 AM
Default Re: (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">have you changed the oil lately, are you using the same grade,
Fresh oil, same grade as always
Oil was as hot as it gets when car is fully warm...actual temperature not known
Point is, 2 months ago with this same scenario, I would get 15 psi higher readings on average
Old Apr 20, 2005 | 04:43 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Fresh oil, same grade as always
Point is, 2 months ago with this same scenario, I would get 15 psi higher readings on average</TD></TR></TABLE>
My oil pressure dropped about 5 psi in the past few months, but its also been warming up outside... The hotter the weather gets your oil pressure will drop a bit.
Old Apr 20, 2005 | 04:45 PM
Crazydave's Avatar
Also the harder you drive the car, the lower the pressure will go,
When I was on the track I would drop from 75 psi to around 45 or 50!
I had to stop and it cool off for a while, and I should have changed oil grade.
Old Apr 20, 2005 | 04:56 PM
My oil pressure dropped about 5 psi in the past few months, but its also been warming up outside... The hotter the weather gets your oil pressure will drop a bit.</TD></TR></TABLE>
I agree, but last august when I was running same grade oil, I had 100 psi at startup, and a constant 75
Its not oil grade...its not the heat...there is more going on...and I will find out what it is!
Old Apr 20, 2005 | 06:09 PM
SOHCmaster's Avatar
Default Re: D16y8-low oil pressure? (civic-4-ges)
Im running a turbo y8 and my guage at first start up is like 80-85psi.. After running it and then idle is around 9psi.. Cruzing at a normal 65mph its like 65psi.. Let off the gas and its around 46psi..Under boost load at WOT its like 85+.... I hope Im ok too..
Old Apr 21, 2005 | 05:52 AM
Default Re: D16y8-low oil pressure? (PK SPEED)
Well I tried some 10W30 last night, helped a bit. Temporary fix to a bigger problem I guess
Old Apr 21, 2005 | 06:05 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Well I tried some 10W30 last night, helped a bit. Temporary fix to a bigger problem I guess</TD></TR></TABLE>
"DO IT!"
Old Apr 21, 2005 | 03:01 PM
Default Re: D16y8-low oil pressure? (LSVTEC 91 Civic)
"DO IT!" </TD></TR></TABLE>
BAH!
Old May 1, 2006 | 05:54 PM
MBlake55's Avatar
hey i was wondering where do u check for low oil pressure on a d16y8 b/c i have a feeling that i have really low oil pressure and i dont kno where to check for it thanx
sasinorm01
Nov 21, 2006 07:26 PM
KooK
May 30, 2006 10:07 AM
RACEPAK
Mar 13, 2006 10:16 AM
PA MATT
Apr 11, 2005 11:29 AM
ricefarmer
Jan 20, 2005 05:59 PM
