for everybody with Evasivice short shifter or B&M with big hole
Old Apr 20, 2005 | 12:31 AM
kinvid22's Avatar
Default for everybody with Evasivice short shifter or B&M with big hole
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvasiveMotorsports.com &raquo;</TD></TR><TR><TD CLASS="quote">Made of stainless steel, it has a CNC machined aluminum pivot housing and spherical bearing. Simple installation instructions included with this professional shifter</TD></TR></TABLE>
When everybody buys it, does everybody wonder why the shifer came with a larger hole in which the bolt doesn't snuggly fit through it?
In response to the description, this isn't true as it doesn't include the spherical bearing. I bought Evasive short shifter some time ago, and the intructions that came with it isn't quite proper. At first I didn't know what to do with the supplied red "O-rings, looked useless at the time. After my install, my shifter was rather noisy-- it rattles when i cruise in 5th gear. Couldn't stand it anymore I decided to swap in a stock shifter I got from a friend. As i was taking it out I noticed the bearing from the stock shifter could be removed from the housing. I took it out and test fit it on the "evasive short shifter" big hole. and wow it fitted perfect! I also realized the little red O-rings is to replace the stock black ones found on the stock shifter bearing.
Basically, you gotta take out the stock shifter's bearing, replaced the O-rings with the supplied red ones(unnecessary), transfer it into the new short shifter. Trust me, after this, this shifter much more smooth, and eliminated the rattling!
hectic57
Feb 27, 2008 08:16 PM
superbeastcrx
Sep 13, 2005 06:09 AM
krisjk2
Aug 16, 2005 05:52 PM
kinvid22
Apr 20, 2005 11:46 PM
eghatchomar
Feb 3, 2005 09:52 PM
