whisling in intake manifold
Old Apr 19, 2005 | 09:53 PM
SHhh__VTEC's Avatar
Default whisling in intake manifold
Like the title says. There's a whisling in my intake manifold. It's a stock manifold on a 2000 h22a. It happens when i'm in gear, and when I turn off the car. This happens when the motor is warm up. It's getting real annoying and i've been put up with it for a while now. It's about time i do something about it.
Does anybody know anything of this or how i can fix this problem? Would I have to get another IM??
Old Apr 20, 2005 | 09:48 AM
SHhh__VTEC's Avatar
anybody??
Old Apr 20, 2005 | 10:00 AM
prelittlelude's Avatar
Default Re: whisling in intake manifold (SHhh__VTEC)
is your car 100% stock?
Old Apr 20, 2005 | 12:30 PM
SHhh__VTEC's Avatar
no hehe not really. there's type s pistons. a lilttle head work. hondata im gasket. aem fuel rail, regulator, intake exhaust. etc...... and others I can't figure what's making the noise......
Old Apr 20, 2005 | 12:39 PM
98TypeSH's Avatar
Default Re: (SHhh__VTEC)
i bet your vac lines are all hooked up wrong. Get the vac diagram out of the helms and double check ALL lines.
Old Apr 20, 2005 | 01:11 PM
Green Lude 93's Avatar
to tell you the truth, it sounds like the intake manifold gasket is leaking if it is whistling. does it idle weird, if so then it could be a vaccum leak with vaccum lines. but i havent heard any vaccum lines whistle when it is unplugged from the manifold which is the reason why i think it is the manifold.
Old Apr 20, 2005 | 01:33 PM
cpforyou's Avatar
Default Re: whisling in intake manifold (Green Lude 93)
maybe it thinks you're cute?
Old Apr 20, 2005 | 01:52 PM
98TypeSH's Avatar
Default Re: whisling in intake manifold (cpforyou)
i had some vac lines hooked up wrong on a previous manifold and it made weird *** whistling noises. Didnt have a weird idle or anything just whistled and made weird noises.
Old Apr 21, 2005 | 07:23 AM
you do know that most colt air intakes make as whistle, my buddyies gsr with a cold air intake always whisles depending on throttle positiona and air temp
Old Apr 21, 2005 | 07:34 AM
caLiH22A's Avatar
Default Re: whisling in intake manifold (prelittlelude)
My car had the whistleing noise also, turned out the screw to adjust the idle level on motor had fallen out. I'm almost sure you have a leak somewhere, you gotta spend some time playing with it, have someone turn it off and on as you pay close attention to the manifold, it helps. GL
Old Apr 21, 2005 | 07:58 AM
PrecisionH23a's Avatar
Default Re: whisling in intake manifold (caLiH22A)
Maybe you have a supercharger and don't know about it.
Old Apr 21, 2005 | 08:09 AM
KILL-A-B's Avatar
Default Re: whisling in intake manifold (PrecisionH23a)
I have that sound too. only vaccum lines are brake booster and catch can.
Old Apr 21, 2005 | 08:52 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">you do know that most colt air intakes make as whistle, my buddyies gsr with a cold air intake always whisles depending on throttle positiona and air temp</TD></TR></TABLE>
Oh yes. My CAI makes a loud whistle sometimes. Some people think I'm running boost or something.
Old Apr 21, 2005 | 09:26 AM
.H22 POWER.'s Avatar
could be a leak in your intake...
Old Apr 21, 2005 | 02:25 PM
951dc5's Avatar
Default Re: whisling in intake manifold (.H22 POWER.)
try spraying carburetor cleaning around and see until you hear the motor sound change and you might find a leak..
Old Apr 21, 2005 | 02:37 PM
SHhh__VTEC's Avatar
hehe, some of ya post are funny. But really, I checked and double checked my vacuum lines with a helms manual. It was happening before I put on the hondata gasket too. It sounds like squeek squeek squeek squeeeeeeek weeeeeee..... It makes the noise when i'm in gear and in constant speed. When I give it gas, the noise goes away. The only time i can hear it when i'm looking under the hood is when i turn it off. And that's for a very short time.
My idle is messed up too. It won't stay still unless I lean it out -20% with the vafc2. It makes the car runs like **** like it's on safe mode (if that's what you call it) sometimes. Feels like a civic dx that fuel pump cuts off at 6500 rpm when it's running safe mode.
Just in case, I'll check the vacuum lines again and i'll go ahead and put the stock intake back on.
Old Apr 21, 2005 | 03:40 PM
Jagan'92's Avatar
Does it only do it when you're going to work?
Old Apr 21, 2005 | 07:39 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .H22 POWER. &raquo;</TD></TR><TR><TD CLASS="quote">could be a leak in your intake...</TD></TR></TABLE>
No leaks. It only does it on hard acceleration. The sound of sucking air.
BIGef
13
Oct 27, 2012 12:25 PM
blackk20dc5
Feb 15, 2009 02:05 PM
99GSRTurbo
Jan 2, 2007 04:17 PM
marble hatch
Oct 16, 2006 07:10 AM
