foaming the chassis
Old Apr 19, 2005 | 09:30 PM
SGVridgerunner's Avatar
Default foaming the chassis
Did the search and found a lot of great info, but one question wasn't answered: Does anybody have a list or diagram of which beams to fill? If I'm going to do this, I want to have a full game plan ready going in to it. Is it just the lower beams outside the car, or the interior pillars as well? The pictures I saw suggested that people here have done this, or at least have seen it done first hand. If you have done this before please share your experience with me, thanks.
Old Apr 20, 2005 | 05:35 AM
Audi RS4's Avatar
Lover
Default Re: foaming the chassis (SGVridgerunner)
why would want to to do this? what are the benefits? I never heard of doing this but it sounds interesting.
Old Apr 20, 2005 | 07:31 AM
Default Re: foaming the chassis (AK1200)
It increases chassis rigidity and dampens sound, kinda breathes new life into an old chassis. Do a search on "chassis foam" it should come back with 2 great threads.
Old Apr 20, 2005 | 04:37 PM
HighPerformance's Avatar
Stolen... er... copied from Sport Compact Car article about foaming a chassis.
Foam-Filling the Chassis
In any high-performance car, it is impossible to make the chassis too stiff. The stiffer the chassis, the higher its natural frequency, making the energy imparted to it by bumps less likely to excite the body's structure. A stiffer chassis enables the use of stiffer springs and shocks without hurting the ride. This is because a stiff, non-flexing chassis transfers more force into the suspension where it can be dissipated by the springs and shocks instead of transferring the force to the occupants. A stiff chassis is also more responsive to roll rate tuning for balancing understeer and oversteer. This is one of the reasons why automotive engineers are continually investigating ways to stiffen chassis without adding weight.
In a final bit of reengineering to stiffen the body, we injected the chassis with catalyzed rigid structural polyurethane foam. Structural foam, in the 2 lb per cubic foot density that we used, can stiffen chassis members up to 40 percent.
Higher densities of foam can increase stiffness by up to 300 percent. Since we cannot retool custom parts to redo the Z's body, we figured that this would be an excellent, low-cost way of greatly increasing chassis stiffness. Injecting foam is not a new technique for chassis stiffening. The Infiniti Q45 uses this sort of foam in some of its chassis members to increase stiffness, as do a few other premium cars. In fact, the foam we chose is the foam recommended to repair damaged Q45s.
To get the correct foam for our project, we contacted Art Goldman, Foamseal's automotive product manager and author of an SAE (Society of Automotive Engineers) paper on the use of structural foam for the stiffening of automotive unibody structures. We used Foamseal's two-component foam kit, p/n 11-22 to fill the main members of the chassis. Like we mentioned earlier, Foamseal is the supplier that I-CAR, a national certification group for quality auto repair, recommends for the repair of damaged, foam-filled chassis. The Foamseal kit uses a two-part catalyzed polyurethane foam, which quickly cures into rigid, waterproof, closed-cell foam. To prep the car, we carefully masked off all painted areas anywhere where the foam could drip. As this sort of foam is a thermosetting catalyzed plastic, we realized it could be icky if it spilled on paint or any part of the car's interior. This foam is nasty stuff. It is impervious to all known solvents and cleaners.
Rubber gloves must be worn. Get some of it on your hands and it will stay there for more than 3 weeks--don't ask how we know. Do not get this stuff on your paint. Wear old clothes; we ruined ours while learning how to handle the product. We injected the foam into the rocker panels and frame rails of Project Z through existing bolt and drain holes. When injected, the foam reacts like shaving cream and quickly expands to fill the empty space. You can judge how much foam to add by watching its expansion progress through some of the holes. Once injected, the foam expands and begins to cure in about a minute so you need to work fast and plan how you inject the foam before you start.
The life of the foam kit is limited to a few hours once the seal is broken. We filled all of the Z's unibody frame members using five foam kits. When foaming a chassis, you must remember the wires and other lines that pass through the chassis must be relocated or they will be entombed forever.
We were amazed at how this simple procedure improved the performance of the car. The chassis now almost feels like it has a roll cage. A sloped driveway can be driven up sideways with nary a creak. Even though the Z already has a pretty tight chassis, it feels more solid. The ride has improved and road noise has been reduced noticeably. We bet that the car will be even more responsive to chassis tuning measures in the future. If you are a slalom racer, a road racer, have a lowered car or even just want a smoother ride; foaming is a worthy, easy-to-do modification. Foamseal has foams in densities as high as 10 lbs per square foot if you desire to make things even stiffer.
Do not--I repeat--do not attempt to use cheap, hardware-store canned foam. This is not the same thing, and if injected into your chassis, will form a gummy mass that won't dry. Foamseal foam is a professional grade foam, which although it is a little unforgiving to cleanup mistakes, has superior mechanical properties and catalytic curing so it will dry even in an enclosed space.
These changes are continually improving and refining Project Z as we eagerly await our motor. We still have some more parts that we will install and review in upcoming issues. Stay tuned, the best is yet to come!
-----Here is a link on where to find some of this stuff------
http://www.sr20forum.com/showt...+foam
Old Apr 20, 2005 | 05:34 PM
drdisco69's Avatar
Default Re: foaming the chassis (HighPerformance)
Excellent info!
Old Apr 21, 2005 | 03:17 AM
Audi RS4's Avatar
Lover
Awesome info......
Old Apr 22, 2005 | 07:12 AM
anotheredhatch's Avatar
what areas on a civic are ideal for foam filling? this is interesting, might have to try this on my track car.
Old Apr 22, 2005 | 11:14 AM
gldndrgn14's Avatar
Default Re: foaming the chassis (anotheredhatch)
anybody order these yet? i couldnt find a dealer from the provided links. any help would be appreciated.
Old Apr 22, 2005 | 09:19 PM
BoostedRx300's Avatar
I would be weary....even though the foam is waterproof, it would still hold water between seams, which = rust!
Old Apr 23, 2005 | 09:48 AM
G2turbo_terror's Avatar
Default Re: (SuperFastS14)
I've been considering this for a very long time but never really looked into it. I might have to open up the helms to day and see if i can come across any good spots. Lets keep this going!
Old Apr 23, 2005 | 05:10 PM
neogenesis2004's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperFastS14 &raquo;</TD></TR><TR><TD CLASS="quote">I would be weary....even though the foam is waterproof, it would still hold water between seams, which = rust!</TD></TR></TABLE>
I dunno, the way they describe it in the article (this stuff doesnt come off even your skin) that is bond to everything makes it sound like as long as you fill the entire cavity then no water will get in wat so ever. This stuff reminds me, may be the same type of foam, of the monster garage episode where they had to build to beetle that drove on water. That stuff made it water proof. It expands to like 6x its original size, there would be no room for anything to get in. Just thinking out loud...
Old Apr 23, 2005 | 06:16 PM
Default Re: (neogenesis2004)
After searching the internet forever I found a site that has the same type of foam as Foamseal, but for a much better price. They also offer 2, 4, 8, 16lb/cubic ft densities. I plan on buying the 8lb/ft foam.
Old Apr 23, 2005 | 06:35 PM
Kookz's Avatar
Resident Vagabond
Share the site!
Old Apr 23, 2005 | 07:18 PM
GForceInteg's Avatar
Default Re: (Kookz)
as another already asked where to foam? the frame rails or actual interior panels?
Old Apr 23, 2005 | 08:02 PM
manekDC2.'s Avatar
Default Re: (GForceInteg)
this is awesome information!! please keep us updated
Old Apr 23, 2005 | 08:47 PM
Default Re: (Kookz)
haha sorry man, i thought i put the link in the post, here it is: http://www.shopmaninc.com/foam.html
now that ive browsed the site more, seems they sell carbon fiber, kevlar, and fiberglass cloths as well. Resin also!
Wuffle
15
Aug 19, 2006 09:12 AM
Bbasso
Feb 16, 2006 09:21 PM
easyFOsheezy
Mar 4, 2005 10:59 PM
Tench
May 9, 2004 04:19 PM
pdonovan11785
13
Sep 15, 2003 04:31 PM
