Skunk 2 Intake
Old Apr 19, 2005 | 08:55 PM
J-Civic SIR's Avatar
Default Skunk 2 Intake
what are peoples thoughts on a skunk 2 intake mani. Good? Bad? OKay?
And also Suggestions on throttle bodies, which one do you think are good, bad and such?
Old Apr 19, 2005 | 10:26 PM
michael O's Avatar
Default Re: Skunk 2 Intake (J-Civic SIR)
I have the skunk2 intake and I guess it's okay. I just got it cuz I couldn't find another intake that would allow me to pass smog at the smog ref. otherwise I'd still be using my first gen b16a intake mani.
Edit:
Ever since I put my skunk2 intake manifold on my intake started making a stupid whistling noise. It is driving me insane.
Oh yea tell us what kinda engine you have and what's done to it and we'll try and help you find a throttle body that works for you.
Old Apr 19, 2005 | 10:30 PM
88ED8's Avatar
Default Re: Skunk 2 Intake (michaelOlson)
My Accord made that same whistling noise, never found out what it was
Old Apr 19, 2005 | 10:33 PM
RCautoworks's Avatar
Default Re: Skunk 2 Intake ('89ED8)
I would save up and by some cams, you will see more power out of a cam or cams. Either way, if your gonna want to add more air to your engine, your gonna need a bigger cam or cams.
I would go with the AEBS intake though, its like $100 dollars and the gains are better then the skunk2 mani
Old Apr 20, 2005 | 01:08 AM
Rywire's Avatar
Default Re: Skunk 2 Intake (90blackcrx)
Im makin great power with my S2, and a set of stg 1 cams
Old Apr 20, 2005 | 01:20 AM
Shirk's Avatar
Default Re: Skunk 2 Intake (droppedcrxsi)
I had the Skunk2 manifold, but it was a pain in the ***. The idle got completely fucked up because there was no room for the FITV. I think all the vacuum connections had to be re-routed, so the mechanic used forever on it. There's no coolant running through it so it got superhot, softened up the Hondata heatshield gasket and let coolant into the cylinders. It took me about three times longer to shift gears, and i guess that's because of the shitty idle.
All this just because I have the EDM B16A1
But, yeah. It DID make top end power
Old Apr 20, 2005 | 06:33 AM
oldSCHOOLhonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’89ED8 &raquo;</TD></TR><TR><TD CLASS="quote">My Accord made that same whistling noise, never found out what it was</TD></TR></TABLE>
did u port match the intake mani gasket?
Old Apr 20, 2005 | 08:09 AM
99teggsr's Avatar
Default Re: Skunk 2 Intake (Shirk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shirk &raquo;</TD></TR><TR><TD CLASS="quote">I had the Skunk2 manifold, but it was a pain in the ***. The idle got completely fucked up because there was no room for the FITV. I think all the vacuum connections had to be re-routed, so the mechanic used forever on it. There's no coolant running through it so it got superhot, softened up the Hondata heatshield gasket and let coolant into the cylinders. It took me about three times longer to shift gears, and i guess that's because of the shitty idle.
But, yeah. It DID make top end power </TD></TR></TABLE>
After this post I am really haveing second thoughts about this manifold, who has something good to say about it?
Old Apr 20, 2005 | 08:23 AM
88ED8's Avatar
Default Re: Skunk 2 Intake (oldSCHOOLhonda)
It was all stock, it only whistle at certin throttle angles.. Don't know whats that about.
Old Apr 20, 2005 | 08:25 AM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’89ED8 &raquo;</TD></TR><TR><TD CLASS="quote"> it only whistle at certin throttle angles..</TD></TR></TABLE>
My b18c1 does this as well.. I don't really mind it though.
Old Apr 20, 2005 | 08:28 AM
crx2fast's Avatar
Default Re: Skunk 2 Intake (Mr_CRX)
the skunk2 mani is basicly the same as an itr intake mani...
Old Apr 20, 2005 | 09:56 AM
88ED8's Avatar
Default Re: Skunk 2 Intake (crx2fast)
I thought they flowed better than ITR manifolds?
Old Apr 20, 2005 | 10:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’89ED8 &raquo;</TD></TR><TR><TD CLASS="quote">I thought they flowed better than ITR manifolds?</TD></TR></TABLE>
Not really
The AEBS out performed them both
Old Apr 20, 2005 | 11:00 AM
88crxvtec's Avatar
I've had my AEBS almost a year with no troubles. IT improved my throttle response and midrange.
Old Apr 20, 2005 | 11:31 AM
Shirk's Avatar
Default Re: Skunk 2 Intake (99teggsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr &raquo;</TD></TR><TR><TD CLASS="quote">
After this post I am really haveing second thoughts about this manifold, who has something good to say about it? </TD></TR></TABLE>
If you have a B16 or B16A2 I believe it's a straight forward bolt on. But if you have the EDM B16A1 it won't fit properly. In other words...it depends on the head (and/or the OBD maybe).
As far as I know B16s didn't come stock with any of your CRXs over there, so the B16s you've got are from '92-&gt; Civics/Del Sols and JDM imports?
Old Apr 20, 2005 | 01:33 PM
slow91crx's Avatar
i have a skunk2 intake mani with a bbk 70mm TB. its nice. idle sucks ***. gets really annoying. sometimes its perfect at a grand but after i crush on it or get the car warm it can get as low as like 200 rmp. o well, mine also makes the wistle sound at certian throttle angles.
tempsohc
27
Dec 11, 2009 03:11 PM
PEK*EGGEM
Mar 8, 2009 01:55 PM
fisherboy1118
Aug 13, 2008 07:47 AM
Eibach95Civic
Mar 10, 2003 06:28 PM
