coilover hell
Old Apr 19, 2005 | 08:08 PM
jayare05's Avatar
Default coilover hell
well, struts and coilovers came in today, so as i attempted to install them, i was taking the back struts out and the bolts snapped. so i had to remove the lower control arms to get the struts out and ofcourse where the bolt holes are for the struts in the lower control arms the bushings where bad and basically fell apart. can i just replace these bushings instead of the whole control arm?
Old Apr 19, 2005 | 08:09 PM
GetawayInMoscow's Avatar
Default Re: coilover hell (jayare05)
Just look for used GSR lower control arms. Actually any integra arms will work, assuming you have an EG of course.
This way you will be able to swap in a nice swaybar in the back too. Pressing in new bushings would be a pita.
Old Apr 19, 2005 | 08:25 PM
mathusala's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayare05 &raquo;</TD></TR><TR><TD CLASS="quote">well, struts and coilovers came in today, so as i attempted to install them, i was taking the back struts out and the bolts snapped. so i had to remove the lower control arms to get the struts out and ofcourse where the bolt holes are for the struts in the lower control arms the bushings where bad and basically fell apart. can i just replace these bushings instead of the whole control arm? </TD></TR></TABLE>
They are pressed in and can be replaced. You can get new ones from Honda for around $50. You can get used ones if the bushings look good. Whatever you get, make sure they have the extra holes for the swaybar.
Old Apr 19, 2005 | 08:30 PM
Lmgrcivic's Avatar
Default Re: coilover hell (mathusala)
yeah depending on if you have a EG just get you some used control arms for about the same price that your going to pay for new bushings and to have them pressed in
Old Apr 19, 2005 | 08:33 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: coilover hell (Lmgrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah depending on if you have a EG just get you some used control arms for about the same price that your going to pay for new bushings and to have them pressed in </TD></TR></TABLE>Listen to this guy. Just get used 94-01 Integra LCA's.
Old Apr 19, 2005 | 10:27 PM
92b16vx's Avatar
The bushings are about 12ea bucks at a supply store. But you would do good to get a hydraulic press to install them. If you can score some GSR LCAs that would be nice too.
Old Apr 20, 2005 | 03:10 AM
ironlung78's Avatar
Default Re: (92b16vx)
or you can buy some aluminum ones with bushings already installed on egay
Old Apr 21, 2005 | 08:14 PM
jayare05's Avatar
Default Re: (sidesi)
i got new control arms ( alluminum ones ) and its all on. took my car around the block to see if it would rub, and when i take sharp corners i think it rubs alittle in the front so ill prob raise it a half inch or so in the front. im taking it for alignment tomorrow, after it is aligned, can i adjust the coilovers without throwing the alignment off? or should i adjust them before taking it for alignment?
by the way.. heres the aftermath after 3 days of hell
Old Apr 21, 2005 | 08:32 PM
SOHC4life 96's Avatar
Default Re: (jayare05)
Adjust them before. Changing the height will screw up the alignment. Mostly the camber though. Toe is more of a big wearing factor than camber, but just set it to what you want to have normally and get it aligned. Find a way to mark that spot and then when you want/need to change it you can and then put it back.
Old Apr 21, 2005 | 08:48 PM
sloweh3's Avatar
Default Re: (SOHC4life 96)
Yea, when you change ride height, toe will change as well. Like SOHC4life 96 said, set it where you want the height and take it in to be aligned.
Car looks damn good w/ the suspension though
Old Apr 21, 2005 | 09:25 PM
jayare05's Avatar
Default Re: (1point6DA)
thanks for the replys and advice!
Old Apr 21, 2005 | 10:37 PM
VRD^sam's Avatar
really nice
Old Apr 22, 2005 | 05:48 AM
jayare05's Avatar
Default Re: (ef9turbohatch)
heres another question, i got an si rear sway bar i wanna throw on. can i just bolt that up without throwin the alignment off? im thinkin its just like the strut bars as long as the struts dont move it should be ok?
apm
Suspension & Brakes
Oct 13, 2007 08:14 AM
stevescivic
Jun 21, 2007 07:48 AM
efking1985
Feb 1, 2007 09:53 AM
thedudefromjerz
Nov 13, 2006 01:44 PM
eg2_RE
Apr 1, 2004 05:56 PM
