F...en CODE 43
Old Apr 19, 2005 | 06:42 PM
ABK's Avatar
ABK
Default F...en CODE 43
My friend is getting code 43 on his 93 coupe. ECU is right and so is the 4 wire o2. Using the stock harness, but extended (not by me) for different location of the o2.
It's only throwing code 43 (which is O2 heater). I checked resistance between green/something wire on the TPS sensor and one of the heater wires it was 0.5ohm (so that's right), I also checked the resistance between second heater wire, and injector junction box (yellow/black wire) resistance was 0.5ohms (so that's right too). Checked the resistance between heater wire terminals on the O2 and it was 13ohms (so that's in spec (10-40 ohms spec)). I also checked if there is voltage flowing to the heater terminals and on of them had 12.xxV and other one had -12.xxV flowing thru them with ignition on. So what the ****, I've even checked the signal wire connetions they were good too.
WHAT the **** is going on?
BTW the CEL goes on after couple minutes after warm up (when it goes into a closed loop).
I HATE O2 SENSORS
Old Apr 19, 2005 | 06:43 PM
civictildeath's Avatar
Default Re: F...en CODE 43 (ABK)
switch the two black wires or whatever color it is ther are 2 of
Old Apr 19, 2005 | 06:45 PM
ABK's Avatar
ABK
Default Re: F...en CODE 43 (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">switch the two black wires or whatever color it is ther are 2 of</TD></TR></TABLE>
You mean two heater wires? I don't think it will make a difference since it's only a resistance circuit, I don't think it has anything to do with polarity. Plus it's still using the original plug which the the right color wires in the right socket, and they seem to have the right polarity flowing thru them (according to the manual).
Old Apr 19, 2005 | 06:56 PM
sensor could be bad then
Old Apr 19, 2005 | 07:00 PM
ABK's Avatar
ABK
well it could be bad but technicaly it says it's in spec. I guess I will try to throw my o2 ouf of my car into his and see what's going to happen. But this is shitty diagnosis.
Old Apr 19, 2005 | 07:26 PM
athoughts's Avatar
I thought code 43 was Fuel Supply system?
Old Apr 19, 2005 | 07:33 PM
EE_Chris's Avatar
Default Re: F...en CODE 43 (athoughts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">I thought code 43 was Fuel Supply system?</TD></TR></TABLE>
It is.
Did this code pop up after the recent O2 extension?
Old Apr 19, 2005 | 07:43 PM
ABK's Avatar
ABK
Default Re: F...en CODE 43 (EE_Chris)
fucken **** I'm retarded. yeah but it still tied in with the O2 isn't???
I don't know when it started coming on because my friend bought the car like that. What do you guys suggest doing?
Old Apr 19, 2005 | 07:52 PM
f1z1c's Avatar
Or fuel pump, lines, regulator, filter, rails, injectors, gas cap etc
Old Apr 19, 2005 | 11:14 PM
athoughts's Avatar
https://honda-tech.com/zerothread?id=1215738
I threw CEL code 43 a few days ago, its gone now but the link above is what some people said to check
circapunk
19
Aug 28, 2007 10:10 AM
GSX TO CX
Mar 5, 2005 10:11 AM
xmd
Oct 12, 2003 10:38 AM
SuperTeg95
Mar 25, 2003 07:04 PM
