VAFC basic setting's
my friend just installed the first gen VAFC in his 99 Si civic , I know he needs to take it to a dyno to have it being do anying benefit, but he needs to have his car be able to drive to the place to tune it.
We did the first intial precedure were u have to hold the trottle at WOT, and close Trottle, but when we start his car it runs funny, its cutting out past 2000 rpm, like its not gettin enough fuel, Is this normal for when u first install a vafc? what do we need to do to get it runing decent so he can get it to a dyno?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Wtf, its not supposed to do anything.
You wire it up and go. Sensor 06 in, 06 out, 4 cyl, upwards-right throttle.
Whats the deal?</TD></TR></TABLE>\
hmmm
he doesnt have a stock bottom end. would that matter?
and we did everthing u said.
hmmm
Make sure you dont have a pervious tune on there. Make sure everythings on 0 and that you did the throttle set up correctly (10 seconds WOT, 10 seconds off, turn off turn on).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Double check your wiring, its not wired up correctly.</TD></TR></TABLE>
thats what im thinking,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Make sure you dont have a pervious tune on there. Make sure everythings on 0 and that you did the throttle set up correctly (10 seconds WOT, 10 seconds off, turn off turn on). </TD></TR></TABLE>
Also i will see if the previous tune is on there still. , but yet we did all the intial settings before u turn the car on, with the WOT and Closed throttle.
ok checked the wire and a wire wasn't makein good connection reset everything It runs now but when it hits were vtec engages nothing happens it bogs done never adjusted vtech point also it smells like it is running rich
did u go in and set everything to 0, even though u recet it, did u go back and just check? if u need to u can just not take it past 5 until u get your car tuned...
yeah , I am going to have Joe look at it and make sure it is all hooked up correct etc etc but the VTM wire was the one that wasn't makeing a good connection. And I hope I didi theWOT part and closed part right but I reset everything
