quick wheel question
I can tell you my experience.
16x7 +40 with 205/50 R15 rubs for me on the outside of the rear wheel well, and at the top of the front wheel well. ~4.5" from the ground. The rear was fixed when I rolled the fender. The front is 'mostly fixed' after pounding the ridge at the top of the wheel well.
16x7 +38 with 205/45 does not rub for me nearly as much. Mostly just the top of the front wheel well when pulling into my driveway (the curbs aren't smoothed by the driveways, just a dull curb to hop.)
YMMV.
If I was you I'd try the 205/45 R16 Hankook Z212 (Ventus R-S2). Discount Tire Direct has them in stock.
-Chris
YMMV.
-Chris
so the actual wheel itself won't rub on any part of the suspension? I would probably go with a 205/45, just figured i'd throw out the 215/45, cause if that worked, a 205/45 should deffinitely work....thanks chris.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curt941 »</TD></TR><TR><TD CLASS="quote">so the actual wheel itself won't rub on any part of the suspension? I would probably go with a 205/45, just figured i'd throw out the 215/45, cause if that worked, a 205/45 should deffinitely work....thanks chris.</TD></TR></TABLE>
You know, I didn't even think about the wheel itself.
16x8 +42
The close part should be in the rear.. 0.5 inch is about 13 mm, so you're 15 mm closer on the inside edge than I am with 16x7 +40.
But, compare this to a 225 tire, which is 8.8" wide, and fits with a +45 offset in the rear.... you should be fine, almost an inch of clearance.
Maybe someone on here is runnning those and can answer for real.
16x8 +42
cool, thanks...i tried thinking about it starting from the 7" wide +48 wheels i currently have, but i don't have my car here to look at clearances or anything, so it wasn't much help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy »</TD></TR><TR><TD CLASS="quote">^ i'm tempted to at times</TD></TR></TABLE>
but do you know if they will fit? i searched but didn't find any threads dedicated to the topic....
ITR3189
Nov 9, 2007 12:34 PM
