Wanna to know witch pin for an air/fuel gauge for a P13
Old Apr 19, 2005 | 03:41 PM
rexadict's Avatar
Default Wanna to know witch pin for an air/fuel gauge for a P13
i have a h22 ek with a p13 ecu. Trying to hook up an air/fuel gauge.
Old Apr 19, 2005 | 03:55 PM
rexadict's Avatar
Default Re: Wanna to know witch pin for an air/fuel gauge for a P13 (rexadict)
BUMP!
Old Apr 19, 2005 | 04:03 PM
Greyout's Avatar
there seems to be a lot of these threads in the last week...
its the solid white wire toward the bottom of the ECU, when looking at it from the position of the passenger's seat:
EDIT: so yours is in a civic, so maybe the ECU is mounted differently. when looking at the ECU from the harness side, the solid white wire is off to the left.... if you used a prelude harness...
Old Apr 19, 2005 | 04:13 PM
rexadict's Avatar
i have a conversoin harness so all the wires are black soooo. i need to know the pin. number
Old Apr 19, 2005 | 05:39 PM
frozenb's Avatar
Default Re: (rexadict)
isn't it hook up to the O2 sensor?
Old Apr 20, 2005 | 06:29 AM
PrettyLude's Avatar
pin it at the sensor itself, its the white wire
Old Apr 20, 2005 | 11:02 AM
Elkins911's Avatar
Default Re: (PrettyLude)
the easiest way is to just plice it into the O2 sensor. takes two seconds and its the same thing as taping into the ECU
StrtRacerB16A2
Aug 27, 2006 10:50 AM
Eg_TypeR
Apr 26, 2006 10:44 PM
boostng r
Sep 18, 2004 10:57 AM
dontcare61776
Aug 16, 2002 04:45 AM
2K1NBGSR
Aug 3, 2002 12:22 AM
