O2 extender and header install
Old Apr 19, 2005 | 02:43 PM
fromhell's Avatar
Default O2 extender and header install
My new header didn't come with an O2 extender and I need to extend my rear sensor about 4 inches. Can I just go pick up some wire and spilce/solder it back together? Car is 96 Civic EX. Thanks for any help
Old Apr 19, 2005 | 10:09 PM
PrettyLude's Avatar
check out http://www.casperselectronics.com they have an extender that is plug and play
Old Apr 20, 2005 | 04:44 AM
JSR's Avatar
JSR
Default Re: O2 extender and header install (fromhell)
I extended my wires by splicing and soldering. No probs.
Old Apr 20, 2005 | 05:00 AM
senpai's Avatar
Default Re: O2 extender and header install (JSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSR &raquo;</TD></TR><TR><TD CLASS="quote">I extended my wires by splicing and soldering. No probs.</TD></TR></TABLE>
me too
Old Apr 20, 2005 | 05:41 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSR &raquo;</TD></TR><TR><TD CLASS="quote">I extended my wires by splicing and soldering. No probs.</TD></TR></TABLE>On what?
I thought the signal wire is shielded, so you just have to know that when you do the splicing. But I'm not sure if it's shielded on all years, all models.
Old Apr 20, 2005 | 06:25 AM
EE_Chris's Avatar
Default Re: O2 extender and header install (JimBlake)
The wire is typically shielded - RG316 can be used.
Old Apr 20, 2005 | 09:09 AM
JSR's Avatar
JSR
Default Re: O2 extender and header install (EE_Chris)
94 Civic with an H22 swap. It wasnt shielded though.
Old Apr 20, 2005 | 02:21 PM
fromhell's Avatar
I've got the O2 sensor extended and soldered back together and it's not throwing any codes so I guess thats a good thing. Thanks for the help
Now for the next problem:
I have everything all put back together but I have a leak where the header meets the cat. What do I use for gaskets?
Old Apr 20, 2005 | 02:29 PM
fromhell's Avatar
Default Re: (fromhell)
Could the flange on the Cat be the wrong size? It's a carsound Cat with the stock civic flange welded on.
Modified by fromhell at 4:55 PM 4/20/2005
mr_munro
11
Dec 1, 2011 07:09 PM
RoB316
Jul 20, 2007 04:58 PM
yellowjdmcrx
Feb 26, 2006 09:23 PM
AZTEKEF9
11
Aug 8, 2005 12:13 PM
ildknyli
May 14, 2004 11:12 AM
