What dizzy is this...
Old Apr 19, 2005 | 10:50 AM
MrPotatoeHead's Avatar
Default What dizzy is this...
I bought this dizzy from a friend, and when I compared it to my dx one ane one plug is WAY differant then other, and one matches. Can you help me?
Please help...I want to do my MPFI swap soon...
Old Apr 19, 2005 | 10:53 AM
EP3_05's Avatar
Default Re: What dizzy is this... (OnE sToCk CrX)
Tough to tell but it looks like an 88-91 civic/crx si distributor.
Old Apr 19, 2005 | 10:54 AM
Mach69's Avatar
It is a distributor with MPFI, as to which obd series it is, im not sure. I am 100% sure that it is NOT a dpfi distributor. It appears to be the '88-'91 Hf or Si distributor, but I'm not so sure.
On one of the arms that hold the distributor to the head, there should be a number on it. For example TD-42U. THATS AND EXAMPLE. Depending on what that number reads, we will be able to tell you exactly what that distributor is from.
Old Apr 19, 2005 | 11:03 AM
Default Re: What dizzy is this... (Mach69)
are they printed on or are they engraved?
Old Apr 19, 2005 | 11:06 AM
FalkenSiR's Avatar
The plugs look different than my old DPFI and my new MPFI....
Old Apr 19, 2005 | 11:28 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: What dizzy is this... (fast88std)
i *think* that is a td-02u or td-22u. either way it looks like the distributor you would need for an mpfi swap. the last distibutor i bought had a sticker, so it might not be stamped anywhere. but the honda factory ones i think are stamped into the metal.
Old Apr 19, 2005 | 11:36 AM
SwissChEz82's Avatar
Default Re: What dizzy is this... (sanimalp)
I'd say D16a6
Old Apr 19, 2005 | 11:39 AM
No-Gi's Avatar
its a MPFI. Look at the round plug, the DPFI has a rectagle plug and the plug is smaller since it is missing 2 wires that you must add when doing the conversion.
Old Apr 19, 2005 | 12:57 PM
Default Re: What dizzy is this... (3_South)
sweet thanks...
Old Apr 19, 2005 | 02:24 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
You can either put the square DX plug on it,
Or get the Si style engine harness plug and
put it on your DX engine harness..
Make sure the round plug has seven wires..
[If it only has five it is a DX..]
For the sake of argument,
Just because it has a round plug does not confirm
it is a MPFI distributor because this is a DPFI distributor
right here:
Also the model number should be stamped here:
Old Apr 19, 2005 | 02:48 PM
Mach69's Avatar
Default Re: What dizzy is this... (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
That is what I was refering to in my post, I forgot if it is ingraved or printed. If you can read you should be able to see it and read it on one of the arms.
I do see 7 wires coming from the plug, so I am 100% that it is some kind of mpfi distributor.
Old Apr 19, 2005 | 10:04 PM
stevenlk's Avatar
it a sohc si dist for a crx
Old Apr 20, 2005 | 12:12 PM
Default Re: (stevenlk)
now any one kno the colors for the wires and what they mean? cuz im going to put the dx plug on it and need to switch wires...Please help...
Old Apr 20, 2005 | 01:55 PM
88DXCRX's Avatar
Default Re: (OnE sToCk CrX)
It is really no problem,
take a look at this pic:
With the exception of the two blue wires on the left,
The five wires are in the same configuration in the dx plug
Compair the two and label them or draw a diagram to go on..
Old Apr 20, 2005 | 02:16 PM
Default Re: (88DXCRX)
is this how you did it?
Old Apr 20, 2005 | 02:37 PM
88DXCRX's Avatar
I used the round plug instead of the square one
This is a DX distributor wired into an Si plug:
If you look at your DX distributor,
the wires will be arranged in the
same configuration in the square plug
Tan may equal orange or peach in your case..Hope this helps..
http://img92.exs.cx/my.php?loc...2.jpg
http://img92.exs.cx/my.php?loc...1.jpg
http://img30.exs.cx/img30/5189/image26gu.jpg
civic accord honda
Jul 27, 2009 06:08 PM
zcsport
Jul 9, 2007 03:58 PM
Badass240SX
Dec 5, 2004 08:37 PM
