something wrong?
Old Apr 19, 2005 | 10:49 AM
whiteef9jdm's Avatar
Default something wrong?
i drive a 98 ex civic coupe and the clutch pedal gradually started to fall to the floor and i had to pump it between gears and now it just sits on the floor and wont engage into any gear . any help would be greatly appreciated.
Old Apr 19, 2005 | 10:54 AM
Cuong-nutz's Avatar
Default Re: something wrong? (whiteef9jdm)
clutch slave cylinder going out on you or the boot.. can't remember which..
Old Apr 19, 2005 | 10:56 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: something wrong? (Cuong-nutz)
Do you have fluid?
Old Apr 19, 2005 | 10:57 AM
deSigi's Avatar
Check for a leak in your clutch line. It works on the same principle as the brake system. If there's a leak the fluid will leak out when you press on the pedal and when you let go air infiltrates itself into the line, giving the pedal a spongy feeling. In your case I think there may be little or no fluid left. Check the fluid level in the reservoir and if it's low top it off.... You'll have to bleed the system though. More importantly try to see if there might be a leak somewhere. You'd be looking for brake fluid (that's what they use in clutch lines).
Old Apr 19, 2005 | 11:08 AM
Default Re: something wrong? (deSigi)
thanks man i just was wondering if i would have to replace something or would it just be a line and fluid. thanks
Old Apr 19, 2005 | 11:22 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteef9jdm &raquo;</TD></TR><TR><TD CLASS="quote">thanks man i just was wondering if i would have to replace something or would it just be a line and fluid. thanks</TD></TR></TABLE>
Check for fluid running down the firewall on the inside of the car directly behind the clutch pedal. If there is fluid there, you need to replace your slave cylinder. If not, then just top off the fluid and bleed it.
Old Apr 19, 2005 | 11:45 AM
Bond's Avatar
Default Re: something wrong? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
Check for fluid running down the firewall on the inside of the car directly behind the clutch pedal. If there is fluid there, you need to replace your slave cylinder. If not, then just top off the fluid and bleed it.</TD></TR></TABLE>
x2
redline7
Feb 17, 2008 12:24 PM
TylerC161
Jun 15, 2007 04:58 PM
epoch707
Feb 21, 2006 06:13 PM
sniperslayer
17
Nov 5, 2005 06:29 PM
Luchini
Oct 16, 2005 06:06 PM
