Can I rewire obd1 distributor to work with an OBD2 harness?
Old Apr 19, 2005 | 08:18 AM
SuicideSlide's Avatar
Default Can I rewire obd1 distributor to work with an OBD2 harness?
For example... can I cut the *2* OBD1 Distributor plugs off and use the *1* obd2 Distributor plug from the obd2 distributor. It has the same amount of total wires. But I dont have the helms manual telling me which wire is which. And some of the wires are different colors....
So any help here guys-
Old Apr 19, 2005 | 08:23 AM
Default Re: Can I rewire obd1 distributor to work with an OBD2 harness? (TurbLu)
Sorry the reason behind all of this is I am replacing my blown b18c (obd2) with a JDM b16a (SIR2)(obd1). And on my harness I have a large 10 plug Distributor plug vs. the 2 part distributor plug on the b16a. So can I use the plug from the gsr dizzy on the b16a dizzy?
Old Apr 19, 2005 | 09:04 AM
bump help please...this is the last thing before I can drop this engine in.
Old Apr 19, 2005 | 09:08 AM
Capt. Jimbo McSubipants's Avatar
when i was gonna drop my obd1 b16a in my obd2 civic..my friend just changed the casing for the dizzy...worked like a charm... instead of rewiring all that ****.. took all obd1 junk and threw it inside obd2 casing..
Old Apr 19, 2005 | 09:18 AM
Marauder's Avatar
Default Re: Can I rewire obd1 distributor to work with an OBD2 harness? (b16delteg)
check out http://www.Rywire.com
If they don't have it, call em up and they take care of you.
Old Apr 19, 2005 | 09:23 AM
pdiggitydogg's Avatar
I dont know how many times I have to post this......Duh, I keep forgetting this is honda-tech...
Old Apr 19, 2005 | 10:42 AM
willyboyK20's Avatar
Default Re: Can I rewire obd1 distributor to work with an OBD2 harness? (Marauder)
so that Rywire distributor harness is for puting an obd-1 distributor on a obd-0 engine, like a 1st gen b16?
But what about if i wanted to put on a obd-1 distro on a obd-0 engine to swap in a obd-2 car? Will that harness work or will i have to completely rewire the distro wiring?
Old Apr 19, 2005 | 11:09 AM
Default Re: (pdiggitydogg)
thanks
Old Apr 25, 2005 | 06:37 PM
Vega Racer's Avatar
Default Re: (TurbLu)
Hey just pack this under the hood and no more Distributor problems.. No one will even notice the blower sticking out of the hood.
Old Apr 25, 2005 | 08:01 PM
The Clash's Avatar
Default Re: (Vega Racer)
They are both the same inside, just rewire the distributor plug to match the harness or vice versa.
Old Apr 25, 2005 | 08:02 PM
Luserkid's Avatar
Default Re: (The Clash)
Yup rewire the 4P, 2P and 4P to 8P and 2P for OBD1 and its done. I did it this last week on an Accord.
Old May 7, 2005 | 10:49 AM
damn old people
Old May 16, 2005 | 09:48 AM
Rywire's Avatar
LOL, well if you just want a jumper we can make whatever.
Ryan
Old May 16, 2005 | 10:47 AM
boostedcivicsir's Avatar
Mr. Badwrench
http://www.lowcashracing.com has dizzy adapter harnesses now for like 25 bucks.
Old May 16, 2005 | 12:10 PM
Hybrid96EK's Avatar
Default Re: Can I rewire obd1 distributor to work with an OBD2 harness? (boostedcivicsir)
There is no need to get any adapter harness. De pin it and repin it to an OBD-2 plug. Its as simple as that.
efdrifter
Nov 8, 2007 09:14 AM
DIYMIKE
Feb 23, 2007 09:06 PM
speedrcr24
Feb 27, 2005 07:16 PM
specie
Jun 14, 2004 06:32 PM
Blown90hatcH
Feb 11, 2003 01:26 PM
