COULD SOMEONE HELP ME?
Old Apr 19, 2005 | 08:07 AM
ONISHIMA's Avatar
Default HELP w/ OIL PRESURE AND WATER TEMP GAUGES
well i was jus wondering if you guys could show me (possibly wiring diagrams) how to hook up an oil pressure gauge pod and a water temp. gauge pod to and acura integra..?
ONI
Modified by ONISHIMA at 9:38 AM 4/19/2005
Old Apr 19, 2005 | 11:29 AM
BlackDAy's Avatar
Default Re: HELP w/ OIL PRESURE AND WATER TEMP GAUGES (ONISHIMA)
well buddy...
for the oil pressure, u need ground, and positive. plug the positive into one of the male connectors right above the fuse box on the inside of your car ( driver side, in front of the door.) that will make it so that when you turn your lights on, the gauge will light up too. Use the plastic oil line that is supplied with the gauge and tap it into the back of the block. (thats the only hard part. i would recommend having it done if u don't know what the f ur doing.) pretty much the same with the water temp, only tap wire into the temp sensor. sorry i don't have any diagrams. they are easy to find on the net though.
Old Apr 19, 2005 | 11:33 AM
smurfey002's Avatar
Default Re: HELP w/ OIL PRESURE AND WATER TEMP GAUGES (BlackDAy)
Are the gauges electric or mechanical?
Old Apr 19, 2005 | 11:34 AM
Honda Hick's Avatar
You also can't just thread in the connector that comes with the gauge into the block. You will need an adapter of some type because the threads will be different on your block. If you aren't too knowledgeable with this I would have a shop install this for you. You don't want to mess up your block or spring a leak in your oil line going to your gauge.
Also, next time you create a thread use a better topic that at least gives a clue as to what you need help with.
Old Apr 20, 2005 | 05:30 AM
ONISHIMA's Avatar
Default Re: HELP w/ OIL PRESURE AND WATER TEMP GAUGES (smurfey002)
there mechanical...
FlatTire
Jul 1, 2004 03:24 PM
Prelude MIke
Jun 9, 2004 11:58 AM
dualknuttz1
Apr 28, 2003 02:57 PM
AutoXsi2000
Jul 27, 2002 06:04 PM
