Energy suspension motor mount inserts question.
Old Apr 19, 2005 | 07:36 AM
Mattmob's Avatar
From: Where we rock teh dookies, Nor Cal, You Es of EY
Default Energy suspension motor mount inserts question.
Ive heard you a can put these on to remedy torn mounts. Has anyone done this and can you tell me of its a good remedy?
Old Apr 19, 2005 | 07:54 AM
EE_Chris's Avatar
Default Re: Energy suspension motor mount inserts question. (Mattmob)
They certainly work - just be ready for some crazy *** idle vibrations.
They are easy too - the upper driver side and upper tranny mount take about 10 minutes each. The rear tranny mount takes awhile longer....
Old Apr 19, 2005 | 08:11 AM
Hybrid96EK's Avatar
Default Re: Energy suspension motor mount inserts question. (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">They certainly work - just be ready for some crazy *** idle vibrations.
They are easy too - the upper driver side and upper tranny mount take about 10 minutes each. The rear tranny mount takes awhile longer....</TD></TR></TABLE>
I don't think I would classify it as anything "Crazy" durring idle. Its slightly more then stock, yes... But by far smoother then running solid mounts such as Hasport.
Old Apr 19, 2005 | 08:16 AM
Mattmob's Avatar
I'd buy the whole kit but I think i'd only install the rear insert since thats the one i need.
Thanks for the quick answer!
Old Apr 19, 2005 | 08:19 AM
DJ_SaNdOz's Avatar
Default Re: (Mattmob)
They are nice, and do cause some extra vibration, but it's not enough to be bothersome. Why not buy a replacement mount set + the inserts? Mounts aren't that costly if you shop around your local parts warehouses....
Razr2
18
Mar 15, 2008 08:59 PM
DeDonDeRosa
Aug 16, 2006 01:00 PM
mckenzie
Apr 6, 2005 02:47 PM
Skyllz
Sep 13, 2003 11:45 AM
Cm91h22a
Jun 13, 2003 05:45 AM
