Energy suspension motor mount inserts question.
Location: Where we rock teh dookies, Nor Cal, You Es of EY
Ive heard you a can put these on to remedy torn mounts. Has anyone done this and can you tell me of its a good remedy?
Re: Energy suspension motor mount inserts question. (Mattmob)
They certainly work - just be ready for some crazy *** idle vibrations.
They are easy too - the upper driver side and upper tranny mount take about 10 minutes each. The rear tranny mount takes awhile longer....
Re: Energy suspension motor mount inserts question. (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">They certainly work - just be ready for some crazy *** idle vibrations.
They are easy too - the upper driver side and upper tranny mount take about 10 minutes each. The rear tranny mount takes awhile longer....</TD></TR></TABLE>
I don't think I would classify it as anything "Crazy" durring idle. Its slightly more then stock, yes... But by far smoother then running solid mounts such as Hasport.
I'd buy the whole kit but I think i'd only install the rear insert since thats the one i need.
Thanks for the quick answer!
Re: (Mattmob)
They are nice, and do cause some extra vibration, but it's not enough to be bothersome. Why not buy a replacement mount set + the inserts? Mounts aren't that costly if you shop around your local parts warehouses....
Razr2
18
03-15-2008 08:59 PM
