Best way to get metal shaving out of oil pan?
Old Apr 19, 2005 | 05:57 AM
fastcivicboy's Avatar
Default Best way to get metal shaving out of oil pan?
Hey everyone I just picked up a z6 oil pan for my turbo project and theres a ton of metal shaving in it. (I mean alot) Ive been trying to get them out for the last hopur but theres still alot left. Anyone know a good technique to get the shavings out. Ive been putting oil draining over and over. Also im about to go out there with a magnet. I dont know we will see what happens. -Nick
Old Apr 19, 2005 | 06:01 AM
turbosi03's Avatar
Default Re: Best way to get metal shaving out of oil pan? (fastcivicboy)
drop the pan and wipe it down..?
RacerXI's Avatar
Default Re: Best way to get metal shaving out of oil pan? (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">drop the pan and wipe it down..?</TD></TR></TABLE>
Pressure washer..
underpressure02's Avatar
I would get some parts cleaner fluid and soak it in that. Or get some brake/parts cleaner and spray that in there swish it around and dump it out. After you get most of it out. Take an air gun and blow everything dry along with the any other dirt/metal in there. Then wipe it down to make sure everything is out of it.
Old Apr 19, 2005 | 07:50 AM
stealthmode62's Avatar
Default Re: Best way to get metal shaving out of oil pan? (underpressure02)
Do what underpressure said. I used gas, swish it around, and dump. Gas cleans the whole thing so effortlessly. It's great.
Old Apr 19, 2005 | 08:12 AM
Default Re: Best way to get metal shaving out of oil pan? (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> Do what underpressure said. I used gas, swish it around, and dump. Gas cleans the whole thing so effortlessly. It's great. </TD></TR></TABLE>
Yeah that might even be cheaper. Or you can use keroscene (sp). Pretty much the same as parts cleaning fluid.
Old Apr 19, 2005 | 09:25 AM
pressure washer did the trick! Would recommend to anyone. Thanks guy's!
Old Apr 19, 2005 | 10:26 AM
Muckman's Avatar
Moderator in Chief
Default Re: (fastcivicboy)
How do you gets get the shavings out of the baffled areas that you cant see or get into? I found swishing water/cleaner around wasn't enough. It just wouldnt come out and I couldnt get a rag in there.
Old Apr 19, 2005 | 11:06 AM
Default Re: (Muckman)
If you can unbolt the baffle, than do that. If you can't, just keep swishing over and over towards the largest hole in the baffle. It just takes time.
Old Apr 19, 2005 | 12:34 PM
Muckman's Avatar
Moderator in Chief
Default Re: (stealthmode62)
unbolt? every one ive seen is welded in.
Old Apr 19, 2005 | 01:13 PM
drift2004's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">drop the pan and wipe it down..?</TD></TR></TABLE>
lol, could not have said it any better
Old Apr 19, 2005 | 01:25 PM
Muckman's Avatar
Moderator in Chief
Default Re: (drift2004)
thats not my quote! fugger.
Dat1BVtecN
Oct 11, 2008 03:47 PM
iukaman
Jan 12, 2008 06:39 PM
tekstyle
May 2, 2006 11:47 AM
crx_pimp
Sep 1, 2005 04:34 PM
gsrcivict
May 20, 2003 10:06 AM
