LS/VTEC Build up, a couple questions
Im using a B18B block and a GSR head. My sleeves are bored out 84mm so i will be using a B20 head gasket. Other than the holes for the dowels is there anything else that i have to do to the head gasket? I saw something about extra material that has to be cut off of there will be a possibily of an oil leak.
http://www.c-speedracing.com/h...t.jpg
you will see the part that says remove.
Blanket Jackson
Sep 12, 2003 08:26 PM
