h22..help
hey i am having some trouble with my h22..it will start and idle fine but once you tap the gas pedal it stalls out? dose anybody know why this may be?
and is it possible to run a h22 prelude on a h23 ecu...until i get my new one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxer518 »</TD></TR><TR><TD CLASS="quote">hey i am having some trouble with my h22..it will start and idle fine but once you tap the gas pedal it stalls out? dose anybody know why this may be?
and is it possible to run a h22 prelude on a h23 ecu...until i get my new one?</TD></TR></TABLE>
its possible to run it but if u do, keep it under 3k rpm to be safe, note u will not have vtec of course
as for the stalling, so anytime u give it any gas other than just letting it sit at idle it stalls??? or if u rev it real quick when it falls back down to idle it stalls???
try checking the TPS voltage at fully closed and then at WOT. I believe it is 0.5 at closed or idle....and 4.5 volts at WOT..I had the same problem and adjusting it was what solved that problem.
i am also thinking that i may have the tps and the egr plugs switched... what color wires do the tps have? and how do you adjust the tps.. i thought there was only one way to put it in....
