91 integra oil plug size
Old Apr 18, 2005 | 10:14 PM
SilviaDriver's Avatar
Default 91 integra oil plug size
does anybody know the size of the oil drain plug for a 91 integra? the hole is stripped so i need to find the size so i can get an oversize plug.
i believe its 6x17mm?
Old Apr 18, 2005 | 11:43 PM
FullRaceCRX's Avatar
Default Re: 91 integra oil plug size (SilviaDriver)
auto parts store should be able to look up the plug and from their you can see what size you need to get
Old Apr 19, 2005 | 09:09 AM
Honda Hick's Avatar
Are you sure it's the pan that's stripped and not the bolt?
If you get an oversized one MAKE DAMN SURE you put the oversized one in straight. It's kind of hard to get it exactly straight because of the angle. I didn't get my oversized one in straight on my old Integra and the head of the new bolt didn't completely seal against the pan and I had a leak. I eventually had to JB Weld the hole and all this other crap because of it.
Old Apr 19, 2005 | 09:24 AM
purplegsr's Avatar
It's actually a 14mm bolt, although the bolt's head needs a 17mm socket. You will notice that your crush washers are 14mm, corresponding with the actual threaded portion of the drain plug bolt.
And as Honda Hick said, be veeerrrrry careful.
Old Apr 19, 2005 | 10:35 AM
XSIWANNAB's Avatar
Default Re: 91 integra oil plug size (purplegsr (Exospeed))
go to autozone ask and they will find,remember the washer if your going bigger
Toonz08
Nov 23, 2008 04:49 PM
Clairvoyant
15
Jun 21, 2006 09:42 AM
coupon
May 9, 2005 03:03 PM
Mt3c
Oct 15, 2003 01:52 PM
gubo22
Oct 29, 2001 10:41 PM
