will the d15b7 valve springs hold the d16a6 cam and 7200 rpm?
i want to swap out my stock dx cam for a 88-91 si/ex cam but i was wondering if the stock valvetrain can handle the cam and higher revs?
thanks
thanks
AFAIK the heads are teh same sans cam, and obviously the OBD differences. From what i remember, the replacement part #'s are teh same for the valve train, so it should work w/o any issues....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec »</TD></TR><TR><TD CLASS="quote">well 7200 isnt that high. it is the stock redline on the d16a6 motor. i just want to get the most out of the cam without hurting the motor. anyone else with any experience?</TD></TR></TABLE>
the d16a6 redlines at 6500
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 »</TD></TR><TR><TD CLASS="quote">
the d16a6 redlines at 6500</TD></TR></TABLE>
uh oh - it's ON now ... just watch
i could of sworn that i heard the valves start floating at 6600 rpm or somewhere around that on a d15b7.and for soem reason redline on the tach for the dx is 6500rpm i belive but fuel cut off is at 6800
I past 6500rpms many times. I think the rev limit is 6800rpms
check out this link
http://tech.hybridgarage.com/tech/specs.htm
check out this link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagnaniEG6 »</TD></TR><TR><TD CLASS="quote">D16a6 redlines at 7100rpms</TD></TR></TABLE>
Are you sure? My other car is a 91 CRX Si with a D16A6 stock and the redline is 6500? Is it different for different years? Are you telling me i can safely take it to 7100rpms?
Many people in the EF forum swear fuel cut is at 7415rpm -
I take my b7 with a6 cam up to 6800 all the time......when I ran a p28 for a while it seen a 7200 a couple times no problems I wouldnt recommend it all the time though.
THEDirtyDseriesWOOT
Dec 10, 2006 07:23 PM
rextec
Apr 19, 2005 02:57 PM
