"Washer trick" on the prelude
Old Apr 18, 2005 | 08:40 PM
Below85's Avatar
Default "Washer trick" on the prelude (Neg. Camber)
Ive recently done a droppage and checked out my rear tires after about 3 weeks worth of riding and decided that they were gettin pretty bald on the inside...to make a long story short, im looking for a cheaper/easier/faster way to get this done. Ive seen a couple diagrams and such of Integras and civics but none on the prelude due to the different suspension assembly. If this is even possible somebody fill me on on where the washers go.
Tyler
I think iv'e looked through all the topics and havnt found anything about this...
Old Apr 18, 2005 | 09:01 PM
bad-monkey's Avatar
Default Re: "Washer trick" on the prelude (Below85)
won't work on a prelude, the rear suspension is different than a DC or E_ suspension.
have you gotten an alignment to zero out the toe? b/c that's what's killing your tires.
Old Apr 19, 2005 | 05:51 AM
Daemione's Avatar
Default Re: "Washer trick" on the prelude (bad-monkey)
I agree - get an alignment to fix your toe, that's the only thing that would show drastic wear in just a few weeks.
Old Apr 19, 2005 | 06:36 AM
john d
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Below85 &raquo;</TD></TR><TR><TD CLASS="quote"> done a droppage </TD></TR></TABLE>
droppage
my camber was pretty bad in the back, i got an spc kit, it was alright
Old Apr 20, 2005 | 05:44 AM
Below85's Avatar
Default Re: "Washer trick" on the prelude (john d)
Thanks for the help, now all i need to do is figure out how to put the camber kit on now
Old Apr 20, 2005 | 07:45 AM
92LudeSI's Avatar
there are 2 bolts on top inside the trunk (you will have to take out the interior panels) take those out and then the control are will drop down and just put in the new camber kit. Its easier to see when its in front of you
professorman
Mar 18, 2010 03:55 AM
flatblack-h22
Apr 13, 2007 03:39 PM
PLude81
Mar 12, 2007 07:31 AM
Bigjussin
Jan 16, 2006 11:26 AM
