engine damper for my 95' civic with b-series motor?
i'm currently looking for some engine torque dampers for my 95' civic. ever since i got my LS swap, wheel hop has been crazy
. i just installed some motor mount inserts in earlier today. it helped the wheel hop, but it's still hopping a little bit. i was told that the NRG damper will work, as long as my driver side upper mount is the one for the car, but it's not, it's for the engine. so what damper would with with a b-series motor in a 95' civic?
What year ls motor are you using, because the 94 and up ls you should have the correct mounts to fit your 95 civic if your using the mount that come with the motor. But if its a 93 and down then get the right mount for you drivers sides upper mount!!! That will help alot with the wheel hop. I have a friend with a gsr swap and i have a b16 in our 94 cx's with no wheel hop.
vicpacdo
Apr 8, 2012 09:45 AM
rally_honda
Oct 3, 2007 12:32 PM
Cloner
Jul 28, 2005 10:17 AM
