engine damper for my 95' civic with b-series motor?
Old 04-18-2005, 07:59 PM
itsJDMyo's Avatar
Default engine damper for my 95' civic with b-series motor?
i'm currently looking for some engine torque dampers for my 95' civic. ever since i got my LS swap, wheel hop has been crazy . i just installed some motor mount inserts in earlier today. it helped the wheel hop, but it's still hopping a little bit. i was told that the NRG damper will work, as long as my driver side upper mount is the one for the car, but it's not, it's for the engine. so what damper would with with a b-series motor in a 95' civic?
Old 04-18-2005, 08:33 PM
civic_tuner's Avatar
Default Re: engine damper for my 95' civic with b-series motor? (itsJDMyo)
Bump, cause I would like to know too.
Old 04-18-2005, 08:59 PM
itsJDMyo's Avatar
Default Re: engine damper for my 95' civic with b-series motor? (civic_tuner)
Old 04-18-2005, 09:11 PM
jeef84's Avatar
Curious as well.
Old 04-19-2005, 08:15 AM
itsJDMyo's Avatar
Default Re: engine damper for my 95' civic with b-series motor? (jeef84)
Old 04-19-2005, 09:17 AM
mwieczorek43's Avatar
Bump. I wanna know as well.
Old 04-19-2005, 07:35 PM
itsJDMyo's Avatar
Default Re: engine damper for my 95' civic with b-series motor? (mwieczorek43)
Old 04-19-2005, 08:47 PM
Sketch_hs's Avatar
me2
Old 04-20-2005, 09:41 AM
itsJDMyo's Avatar
Default Re: (Sketch_hs)
Old 04-20-2005, 10:12 AM
92-LS-Civic's Avatar
Default Re: (itsJDMyo)
ill move this back to the top because i have wheel hop to with my b series.
Old 04-27-2005, 05:16 PM
Sketch_hs's Avatar
Still waiting!
Old 04-27-2005, 05:30 PM
turboxsi's Avatar
What year ls motor are you using, because the 94 and up ls you should have the correct mounts to fit your 95 civic if your using the mount that come with the motor. But if its a 93 and down then get the right mount for you drivers sides upper mount!!! That will help alot with the wheel hop. I have a friend with a gsr swap and i have a b16 in our 94 cx's with no wheel hop.
vicpacdo
04-08-2012 09:45 AM
rally_honda
10-03-2007 12:32 PM
Cloner
07-28-2005 10:17 AM
B16Hatchcx
07-29-2003 08:56 PM
Quick Reply: engine damper for my 95' civic with b-series motor?
