My N2O fogger setup on ITBs
Old Apr 18, 2005 | 07:36 PM
2KWK4U's Avatar
Default My N2O fogger setup on ITBs
I just finished bending the lines tonight, and I think it turned out pretty good.
What do you think?
Old Apr 18, 2005 | 08:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: My N2O fogger setup on ITBs (2KWK4U)
looks good, but the foggers look way too close to the head
Old Apr 18, 2005 | 08:25 PM
2KWK4U's Avatar
You really do not have much room to work with. It should not be a problem though.
Old Apr 19, 2005 | 12:33 AM
5STAR3's Avatar
Default Re: (2KWK4U)
i think they look pretty sick.
any bigger pictures?
Old Apr 19, 2005 | 01:04 AM
2KWK4U's Avatar
Those pics are big, too big, and i serve will mot let me resize them. I will see what I can do.
Old Apr 19, 2005 | 04:14 AM
SOHFAST94's Avatar
Default Re: My N2O fogger setup on ITBs (wantboost)
How do you figure? You see where the stock injector location on those ITB's are? That's where I have mine on 12.42:1CR except I'm running alcohol instead of fuel.
Old Apr 19, 2005 | 06:34 AM
HondaTechIsTheGay's Avatar
Yeah they look sick, but anymore bigger pictures?
Old Apr 19, 2005 | 09:37 AM
david@didrace.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">looks good, but the foggers look way too close to the head</TD></TR></TABLE>
For a wet kit you want the jets as close as possible to the valves.
Old Apr 19, 2005 | 05:49 PM
2KWK4U's Avatar
Default Re: My N2O fogger setup on ITBs (LSVTEC_DC2R)
this is too big of a pic
Old Apr 20, 2005 | 01:06 AM
137's Avatar
137
itb's and nitrous... thats gonna be nuts.
Old Apr 20, 2005 | 09:31 AM
Boostage's Avatar
Default Re: My N2O fogger setup on ITBs (137)
I notice the fuel bungs are before the nozzles, that could be bad.
Old Apr 20, 2005 | 10:55 AM
CRseXy's Avatar
Default Re: My N2O fogger setup on ITBs (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">I notice the fuel bungs are before the nozzles, that could be bad.</TD></TR></TABLE>
yah thats what I was about to say. I would have ran the NOS before the inejectors. running them after I think your going to have lean issues, but that can go away with tuning. but for the intial burst its going to run lean I think.
what I would have did is run the nos nozles UNDER the ITBS right before where the injectors are spraying. I dont know alot about nos. but I know wet is better.
Old Apr 20, 2005 | 11:57 AM
mrDFWmechanic's Avatar
that looks crazy
Old Apr 20, 2005 | 05:41 PM
ferio 95's Avatar
Default Re: My N2O fogger setup on ITBs (pogiTSI)
how is a wet shot going to run the motor extra lean
Old Apr 20, 2005 | 05:43 PM
ferio 95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">
what I would have did is run the nos nozles UNDER the ITBS right before where the injectors are spraying. I dont know alot about nos. but I know wet is better.</TD></TR></TABLE>
how is a wet shot going to run the motor extra lean its obvious you dont no much aobut nitrous. but, when running a wet shot you match the fuel to the spray in the fogger so that it wont run to lean. coming before or after the injectors wont matter. i do agree on mounting them on the underside only to hide it nice setup man. same thing i had planned
Old Apr 20, 2005 | 05:47 PM
2KWK4U's Avatar
Do to the throttle linkage setup, there is no room available on the underside, otherwise that is the way I would have done it too.
Old Apr 20, 2005 | 07:24 PM
Boostage's Avatar
Default Re: My N2O fogger setup on ITBs (ferio 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">
how is a wet shot going to run the motor extra lean its obvious you dont no much aobut nitrous. but, when running a wet shot you match the fuel to the spray in the fogger so that it wont run to lean. coming before or after the injectors wont matter. i do agree on mounting them on the underside only to hide it nice setup man. same thing i had planned </TD></TR></TABLE>
The extra fuel in a wet shot is to help neutralise the more direct blast of nitrous in direct port setup. it Might provide enough fuel to prevent a lean situation.
Old Apr 20, 2005 | 07:36 PM
Infinite Auto's Avatar
The extra fuel in a wet shot is to help neutralise the more direct blast of nitrous in direct port setup. it Might provide enough fuel to prevent a lean situation.</TD></TR></TABLE>
ok from what i know about n2o thats pretty ignorant....
dry kit = nozzle sprays n2o and fuel injectors make up for the added oxygen content
wet kit = nozzle sprays n2o and also the enrichment fuel, taking the strain off of the injectors
correct me if im wrong......the fuel isnt there to "neutralise" the n2o, its there to make power with the %33 oxygen being sprayed in
Old Apr 20, 2005 | 08:14 PM
Boostage's Avatar
Default Re: My N2O fogger setup on ITBs (B18TurboEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18TurboEF &raquo;</TD></TR><TR><TD CLASS="quote">
correct me if im wrong......the fuel isnt there to "neutralise" the n2o, its there to make power with the %33 oxygen being sprayed in</TD></TR></TABLE>
um, you do realise that when nitrous is directly injected into cylinder especially larger shots, it would be easier to run lean and blow if there isnt added fuel? on a dry shot as soon as the throttle body closes between shifts nitrous cant enter the motor, when you shift with a direct setup, nitorus doesnt stop spraying between shifts. and if you shift like a normal person (easing off the gas and pressing the clucth) then you could have a really ugly situation.
Old Apr 20, 2005 | 08:30 PM
um, you do realise that when nitrous is directly injected into cylinder especially larger shots, it would be easier to run lean and blow if there isnt added fuel? on a dry shot as soon as the throttle body closes between shifts nitrous cant enter the motor, when you shift with a direct setup, nitorus doesnt stop spraying between shifts. and if you shift like a normal person (easing off the gas and pressing the clucth) then you could have a really ugly situation.</TD></TR></TABLE>
well first im not saying im right, nor trying to be a dick, just sharing my knowlege
now yes i do understand it would be much easyer to blow up an engine if you dont add fuel to the n2o, but i believe you are way off on 2 things:
1. i believe most n2o kits will automatically stop spraying durring a shift, that just seems logical to me (basing this from my old zex kit)
2. assuming #1 is wrong, if the kit keeps spraying durring a shift, it will spray both n2o and fuel at the same time (being that its a wet kit) so you would not have any of the problems you are talking about.
also another thing to point out, there are also many wet kits that spray before the throttle body. the "pre-throttle body" kits wether dry or wet are for a smaller shot design, they dont have any way to evenly distribute the mixture to the cylenders other than air flow which can vary quite a bit depending on your intake manifold design. they also have the well known problem of "pooling" in the intake manifold at a lower rpm, when the mixture gets "stuck" in an area of the intake manifold and with any hicup can blow your intake manifold off the motor.....so the direct port wet kit is the most effective from what ive read
Old Apr 20, 2005 | 08:56 PM
Boostage's Avatar
this was my point thats the reason why direct port kits has extra fuel, now is it enough fuel to prvent a lean burn when..
a. its sitting AFTER the primary injectors
b. The injectors cut during shifts
anyway we will see, hopefully this guy has no issues
Old Apr 20, 2005 | 09:08 PM
i butched your post, but thats what im responding to.....
asuming the tune of the persons engine is perfect (obviously its not but it would be affected the same) it would not matter if the injector sprays less durring the shift, the fuel that the n2o needs is being sprayed by the fuel nozzle, a wet kit works completely independant of the motor.
Old Apr 20, 2005 | 09:55 PM
CRseXy's Avatar
ahhh as you can see, its had 2 ports on each nozzle. blue and red. Im assuming red is for nos. and blue is for fuel. because hes running both fuel and nos thru the same nozzle. It shouldnt matter where the nozzle is put, before or after the injector.
Old Apr 21, 2005 | 08:21 AM
SL0WEGG's Avatar
the nitrous shouldnt stay on during shifts if its hooked up properly. most use a full throttle micro switch so once you left of the as to shift it will turn off and once you get back on the gas to turn back on. there should be atleast two switches for the nitrous. one to turn the whole thing on. and the WOT switch to activate the nitrous. setup looks really clean
Old Apr 21, 2005 | 01:03 PM
m R g S r's Avatar
ya i was gonna say...where the injectors normally go looks blocked off....
