Aluminum Barb Fittings
Old Apr 18, 2005 | 06:54 PM
turbo gli's Avatar
Default Aluminum Barb Fittings
anyone know were to get some of them .. ive been searching all over .. summit ,jegs ext .. looking for various sizes for diff hose . also -6 would equate to what 3/8 ?
like these .. i will be welding them kinda like that ..
Old Apr 18, 2005 | 07:07 PM
dfoxengr's Avatar
Default Re: Aluminum Barb Fittings (turbo gli)
get some full thread nipples and the weld them on. then screw a female thread/barb on that...?
or even a coupler welded onlike an O2 sensor bung, then a males barb into that?
let me kno if you want to do that, i can get them for you in a few days
Old Apr 18, 2005 | 07:15 PM
dfoxengr's Avatar
Default Re: Aluminum Barb Fittings (hybridvteceg)
and 1/4"NPT is 6an
Old Apr 18, 2005 | 08:08 PM
AceRaceParts's Avatar
Those look like male x hose barb fittings. I'll look tomorrow when I get to work if we have any in stock. Is aluminum a must?
Old Apr 18, 2005 | 08:56 PM
dfoxengr's Avatar
Default Re: Aluminum Barb Fittings (mbpwrx)
im sure his can is alum so it probably is a must.
Old Apr 18, 2005 | 10:49 PM
turbo gli's Avatar
yea i need aluminum .. alum so it can be straight welded to the can .. there pritty much the brass nipples u see at osh and **** .. just in alum .. any online source for em?
rich hook it up . u came threw on the s.s elbows for me .. let me know if u guys stock thoes barb fittins in alum .. dont matter about the threded size as long as the barb is for 1/4 hose ..
Old Apr 19, 2005 | 06:31 AM
dfoxengr's Avatar
check out my idea under your first post
Old Apr 19, 2005 | 08:45 AM
I just checked on the fittings and the smallest we have are 1/2" male x 1/2" hose barb.
I wish I could help but you might have to find an alternative...1/4" x 1/4" is pretty small for aluminum hose barb fittings.
Old Apr 19, 2005 | 09:04 AM
stizzit's Avatar
Closest i could find...
1/2" hose ID which is -8an Hose to male pipe threaded adaptors (cut off threads, weld on).
http://www.mcmaster.com part # 5363K21
Old Apr 19, 2005 | 09:09 AM
Default Re: Aluminum Barb Fittings (stizzit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit &raquo;</TD></TR><TR><TD CLASS="quote">Closest i could find...
Read the post right about yours. I said we carry the 1/2" x 1/2". However, if you need them asap your best bet would probably be McMaster because it looks like we are 2-3 days out.
Old Apr 19, 2005 | 09:23 AM
gldndrgn14's Avatar
is that a fuel accumulator tank?
Old Apr 19, 2005 | 10:37 AM
dfoxengr's Avatar
Default Re: Aluminum Barb Fittings (gldndrgn14)
like i said, why not just weld a bung on and screw a 1/4 brass one in there?
Old Apr 19, 2005 | 03:58 PM
stizzit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbpwrx &raquo;</TD></TR><TR><TD CLASS="quote">Read the post right about yours. I said we carry the 1/2" x 1/2". However, if you need them asap your best bet would probably be McMaster because it looks like we are 2-3 days out. </TD></TR></TABLE>
So because you carry them he must buy from you? Just giving him some options ... chill.
Old Apr 19, 2005 | 05:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit &raquo;</TD></TR><TR><TD CLASS="quote">So because you carry them he must buy from you? Just giving him some options ... chill.</TD></TR></TABLE>
Yep, that's exactly what I said. If that's what you thought I meant, I'm sorry.
He's bough from us before and I was trying to help him out again. We are cheaper than McMaster so that's why I pointed him in my direction after you mentioned McMaster.
Modified by mbpwrx at 2:15 AM 4/20/2005
Old Apr 19, 2005 | 08:35 PM
turbo gli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">like i said, why not just weld a bung on and screw a 1/4 brass one in there?</TD></TR></TABLE>
i understand .. but y . if i could just weld a threded barb fitting to it .. know what i mean .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbpwrx &raquo;</TD></TR><TR><TD CLASS="quote">Yep, that's exactly what I said. If that's what you thought I meant, I'm sorry.
Modified by mbpwrx at 2:15 AM 4/20/2005</TD></TR></TABLE>
yea rich at ace stainless is cool peoples .. and prob will always be cheaper then mcmaster ..
Old Apr 19, 2005 | 08:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo gli &raquo;</TD></TR><TR><TD CLASS="quote">i understand .. but y . if i could just weld a threded barb fitting to it .. know what i mean . </TD></TR></TABLE>
Paco..you're going to have a real hard time finding the fitting with 1/4" hose barb in aluminum. For some reason they either just aren't made or are extremely hard to come by. I made about 5 or 6 phone calls today trying to find something that would work for you and none of the master distributors or mills could help me. If worse comes to worse you could always opt for Hybrid's suggestion (it's a good suggestion but I'm sure it's more work than you wanted).
Thanks for the kind mention..I didn't mean to come across rude in the last post and I hope things are cleared up.
Old Apr 19, 2005 | 09:09 PM
turbo gli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbpwrx &raquo;</TD></TR><TR><TD CLASS="quote">Paco..you're going to have a real hard time finding the fitting with 1/4" hose barb in aluminum. For some reason they either just aren't made or are extremely hard to come by. I made about 5 or 6 phone calls today trying to find something that would work for you and none of the master distributors or mills could help me. If worse comes to worse you could always opt for Hybrid's suggestion (it's a good suggestion but I'm sure it's more work than you wanted).
Thanks for the kind mention..I didn't mean to come across rude in the last post and I hope things are cleared up. </TD></TR></TABLE>
thats gey .. i dont see y no one would make one ? ..thanks for trying to help me out i really appricate it man .
well how do u guys think this barb / hose fitting will hold up .. i plan on running socketless hose .. so the reason for a barb fitting .. u think the hose will have probs sealing good over one of these ? there will NOT be under any kind of extream pressures as the inline pump is After the tank ..
Old Apr 19, 2005 | 09:13 PM
What is the diameter of the barb and what is the diameter of the tubing (non-barbed area)? You might be able to get away with using that fitting and a worm-gear hose clamp.
If you by chance can use nickel plated steel (which I highly doubt) we have them 1/4" x 1/4"...but that won't go too well with aluminum.
Old Apr 19, 2005 | 09:16 PM
turbo gli's Avatar
its 1/8 ntp / 1/4 barb (6an) .. so i think i can get away with it .. i dont see how a socketless hose would ever leak on that .. thoes - even tho they say socket less push lock hose . are fucken hard as **** to get over a barb fitting .. + is will just be holding gas flow . the tank will never see pressure ..
Old Apr 20, 2005 | 01:25 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbpwrx &raquo;</TD></TR><TR><TD CLASS="quote">What is the diameter of the barb and what is the diameter of the tubing (non-barbed area)? You might be able to get away with using that fitting and a worm-gear hose clamp.
If you by chance can use nickel plated steel (which I highly doubt) we have them 1/4" x 1/4"...but that won't go too well with aluminum. </TD></TR></TABLE>
jb weld it y0z
Old Apr 20, 2005 | 08:26 AM
dfoxengr's Avatar
right but it seems youre having trouble finding one, so theres another option.
Old Apr 20, 2005 | 08:28 AM
dfoxengr's Avatar
more work?lol
its the same amount of welding. only extra work involved is screweing in the brass fitting. that IS a lot of work...
1sick4g63
Welding / Fabrication
10
Apr 2, 2013 06:10 PM
nasteboyii
Oct 19, 2004 08:09 AM
boostedsol
Sep 11, 2003 02:04 PM
Xerxes
Jan 27, 2002 10:48 PM
