axle popped out wHY!
Old Apr 18, 2005 | 06:42 PM
blkgsr03's Avatar
Default axle popped out wHY!
my axle popped out outta no where today, no crazy driving jus caual.. any ideas why axle would pop out?
Old Apr 18, 2005 | 06:59 PM
Deemeetree's Avatar
Electrician
Time for a new one?
Have you ever replaced it? Maybe the circlip at the spline gave out?
Old Apr 18, 2005 | 07:48 PM
blkgsr03's Avatar
Default Re: (Dimi)
yeah i think i need a new one. but why did it jus pop out like that. thats dangerous if every honda did that.
Old Apr 18, 2005 | 07:51 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (CTRb18c)
ok wait.. what part fell out? the input spline to the tranny? or the hub of the wheel?
do you have a swap? is your car lowered?
if you have a swap, are you using 92+ integra axles?
and it could be as simple as the retaining ring inside the diff is worn out, or missing.
Old Apr 18, 2005 | 08:14 PM
tur3oDC4's Avatar
Default Re: (Built B16A)
Its happened to 2 of my freinds - both cauter pins fell out. check it.
Old Apr 18, 2005 | 08:26 PM
blkgsr03's Avatar
Default Re: (whitepoweredlsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitepoweredlsvtec &raquo;</TD></TR><TR><TD CLASS="quote">Its happened to 2 of my freinds - both cauter pins fell out. check it.</TD></TR></TABLE>
ic ic POS axles man. wtf. well hopefully its that. do i need to go to autozone and purchase a remanufactured axle?
Old Apr 18, 2005 | 08:34 PM
Archidictus's Avatar
Unceasing Measure
Axles don't have cotter pins in them...do you mean the retaining ring clip that holds the axle in the tranny? The only cotter pins that could effect the axle are the ones that retain the castle/crenelated nut on the ball joints.
Old Apr 18, 2005 | 11:27 PM
clutcher's Avatar
i know the ball joint on my car has some play in it... when my axle popped out on my 95 gti vr6 it was a broken ball joint that caused it... but since the honda has 2 i'm not so sure...and i'm kinda new to honda repairs
Old Apr 19, 2005 | 10:31 PM
Built B16A's Avatar
yes.. the axle has expanding retaining rings. if its not pressent, the axle can walk out of the differencial. thats what you need to check.
Old Apr 20, 2005 | 01:42 PM
tur3oDC4's Avatar
retaining rings - I appologize .. u knew what i meant.
Old Apr 20, 2005 | 05:29 PM
civicVX's Avatar
Default Re: axle popped out wHY! (CTRb18c)
how much is your car lowered? if it is replace the axal if it does it again chances are it is to low.
freshvibes
Nov 23, 2007 07:54 AM
whatsthatnoise
Oct 10, 2006 03:09 PM
nonvteclude
Aug 7, 2006 08:45 PM
FormulaGSR
Oct 5, 2004 04:34 PM
Tad
30
Jun 27, 2004 08:09 PM
