Stock Ex Engine Need Info
Old Apr 18, 2005 | 06:32 PM
HksHaitian's Avatar
Default Stock Ex Engine Need Info
How realiable is the stock ex engine from a 97 civic???
I know that it has a 125hp vtec sohc, is it capable of any power???
And wat the engine's code???
Old Apr 18, 2005 | 06:35 PM
MiMiK's Avatar
engine code is d16y8.
best power made on a sohc is from a turbo.
Old Apr 18, 2005 | 06:36 PM
EVIL Hx Coupe's Avatar
Default Re: Stock Ex Engine Need Info (HksHaitian)
D16Y8 - Engine Code
127HP - Stock HP
Very reliable engine if taken care of properly (oil changes, tune ups). Very capable of nice WHP numbers when built and turboed.
civiccpedx's Avatar
Default Re: (MiMiK)
i have seen d16y8's make around 300whp with a turbo. that is the best form of power for that engine. it has plenty of potential, stick with it, parts are cheap and they turbo's are easily thrown together.
Koyoloeor's Avatar
Default Re: (MiMiK)
Turbo the D series!!! or swap it out and sell it to me! good luck
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
An SOHC vtec is capable of good power. A lot of the members are still rocking the SOHC. Just wait till they get on this thread and tell u.
HksHaitian's Avatar
Default Re: (MiMiK)
i'm talk about w/o a turbo, can i just build the motor
Old Apr 18, 2005 | 06:38 PM
HksHaitian's Avatar
Default Re: (HksHaitian)
Is it true that u can't feel the vtec kick in with the sohc engine???
Old Apr 18, 2005 | 06:39 PM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
Default Re: (MiMiK)
Very good engine one of the best trannys also. It's just as reliable as the loose nut behind the wheel though. Keep it if not through it away in my trash can I'll dump it for you.
Old Apr 18, 2005 | 06:41 PM
Power can be made without turbo, but you'll end up spending around the same amount of money and wont make anywhere near as much HP.
VTEC? It's there buy you wont feel it much. After all it's just a 120hp motor in a 2500lbs car, cant really feel much of anything untill you do some work to it.
Old Apr 18, 2005 | 06:53 PM
HksHaitian's Avatar
Default Re: (EVIL Hx Coupe)
hey can i keep the d16 block and put on a b-series head???
Old Apr 18, 2005 | 06:57 PM
jethawk's Avatar
No
Old Apr 18, 2005 | 07:02 PM
nota-ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HksHaitian &raquo;</TD></TR><TR><TD CLASS="quote">hey can i keep the d16 block and put on a b-series head???</TD></TR></TABLE>
Nah. Pretty much all D series things are interchangeable with other D series. Most B series with other B series, but B&D parts don't mix.
Old Apr 18, 2005 | 07:17 PM
HksHaitian's Avatar
Default Re: (nota-ex)
ok thanx
Old Apr 19, 2005 | 06:12 AM
blacks13ek's Avatar
i swapped in a 99 d16y8 into my ek, you can feel the power increase from the regular d16y7 motor. But as far as VTEC, no i dont feel a thing. I think its a good start for someone just getting into the scene.
Old Apr 19, 2005 | 07:13 AM
Royal_C!ty's Avatar
Default Re: (blacks13ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacks13ek &raquo;</TD></TR><TR><TD CLASS="quote">I think its a good start for someone just getting into the scene.</TD></TR></TABLE>
I'd have to agree to that ... and i believe you should definitely go boost . because just bolt on's and such will add up some hp & tq. but it doesn't give you a big change (&lt; - - - might be a little confusing) but anyways just turbo the D
Old Apr 19, 2005 | 08:05 AM
al3e's Avatar
Default Re: Stock Ex Engine Need Info (rukawa1one)
yep. im running SOHC...225ish Whp non turbo
just kidding. i have a stock 130ish d16z6!
chelt_scene
Jul 29, 2009 04:57 PM
Hawks-At-Angels-12
Feb 4, 2006 12:44 PM
ricetoniceeg
Apr 2, 2005 07:51 PM
J0nothan
Feb 28, 2005 01:21 PM
hcivic99
Nov 10, 2004 10:09 PM
