H22a/F22a1 Frankenstien
Old Apr 18, 2005 | 05:31 PM
Officer's Avatar
Default H22a/F22a1 Frankenstien
I was looking on cb7tuner.com and got some info, but just curious if anyone over here has done this swap. I would like some more inof, like what all is invoved but if anyone has got any knowledge to spare i would appreciate it. Thanks
Old Apr 18, 2005 | 10:49 PM
Sam1am26's Avatar
Default Re: H22a/F22a1 Frankenstien (TotaledHatch)
Yeeeeep...
https://honda-tech.com/zerothread?id=776837
Old Apr 19, 2005 | 09:22 AM
ben1818's Avatar
Default Re: H22a/F22a1 Frankenstien (Sam1am26)
Its easy to do that swap it bolts right in and you use your old wriing harness and just add a couple of wires you have to add the knock sensor, vtec pressor sensor, vtec sensor, and an IAB wire thats all
Old Apr 19, 2005 | 05:14 PM
Sam1am26's Avatar
Default Re: H22a/F22a1 Frankenstien (ben1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben1818 &raquo;</TD></TR><TR><TD CLASS="quote">Its easy to do that swap it bolts right in...</TD></TR></TABLE>
Well... The head does just bolt right on but there are a few modifications you have to do to make the head and block work together.... You have to block two drains in the h22 head that do not exist on the f-series blocks...(NOTE: These are the only two passages that do not line up from the head and block...) You also have to make your own custom waterpipe using the bottom half from an f22/23 and the top half from an h22... And you also have to pull the waterpump gear off of an h22 waterpump and press it onto the waterpump housing of an f22/23... But mechanical wise, that is all....
And just a note for all you, the most simple swap you can do is an f-series block with an h23 head.... The h23 head does not have the same two oil passages that do not line up in the h22 head... I repeat, an h23 head lines up perfectly with an f-series block passage for passage... And the h23 waterpipe fits perfect .. The only thing you would have to do would be to put an h23 waterpump gear on an f-series waterpump housing....
Both swaps you will need the lower crank gear that corresponds to the head and obviously you will need head specific items such as intake/exhaust manifolds, dist, themo housings, etc...
Old Apr 20, 2005 | 08:16 AM
ben1818's Avatar
is he just swaping the head or the hole engine if hes doing the engine then it will just bolt right in I help a friend with it and it was simple to do right now Im putting the H22 into a 1991 prelude now that is a lot harder to do
Old Apr 20, 2005 | 10:39 AM
Ministry's Avatar
he's talking about doing a H & F series hybrid (aka G series )
I don't think he's talking about just bolting in an F series
Old Apr 20, 2005 | 12:21 PM
ben1818's Avatar
Default Re: H22a/F22a1 Frankenstien (dreamer)
ok I have a question will not having the O2 sensors hooked up mess up the timing because my car will start but then the timing get thrown off and will die but I dont have the exaust on so I dont have any of the O2 sensors hooked up will hooking them up fix it?
Old Apr 27, 2005 | 04:32 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">he's talking about doing a H & F series hybrid (aka G series )
Sorry, but G-series is already taken - the G25 in the Acura Vigor.
Old Apr 27, 2005 | 04:55 AM
Sam1am26's Avatar
Default Re: H22a/F22a1 Frankenstien (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry, but G-series is already taken - the G25 in the Acura Vigor.</TD></TR></TABLE>
That's actually been brought up before but since no one talks about those and g comes between f and h, were just letting it roll...
mr_munro
May 25, 2021 08:27 PM
TheRookie74
Sep 7, 2014 09:59 PM
nathanjohnson2009
Jan 12, 2010 09:51 PM
ludeatik22
Jun 25, 2009 02:15 PM
sitinthehall
Jul 30, 2005 01:44 PM
