y8 manifold
Old Apr 18, 2005 | 04:30 PM
mr. carpenter's Avatar
Default y8 manifold
i'm puttting a y8 manifold on a z6. which gasket do i use?
Old Apr 18, 2005 | 05:13 PM
dr_latino999's Avatar
Default Re: y8 manifold (mr. carpenter)
Either or
Old Apr 18, 2005 | 06:05 PM
92integra_gs's Avatar
doesnt matter all gasket in the d-series are interchangeable....
Old Apr 18, 2005 | 06:09 PM
Default Re: (92integra_gs)
well i ask because the two gaskets are different and i'm getting a mad vacum leak at the manifold. i've the z6 gasket on now. when i spray carb cleaner at the seal it sucks in and bogs down.
Old Apr 18, 2005 | 06:12 PM
Default Re: (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">well i ask because the two gaskets are different and i'm getting a mad vacum leak at the manifold. i've the z6 gasket on now. when i spray carb cleaner at the seal it sucks in and bogs down.</TD></TR></TABLE>
i would use hondabond or gasket sealer... are you using new or old... your suppose to replace them... if not i would really use gasket sealer...
Old Apr 18, 2005 | 06:18 PM
Outsane's Avatar
or get a hondata or a similar..
Old Apr 18, 2005 | 07:43 PM
Default Re: (Outsane)
it's a new gasket. the car is steady idling at 2k and sucking air.
Old Apr 20, 2005 | 03:29 PM
i just found out that 99-00 Y8 IM has like air injection system that will cause massive vacuum leak...
see if you got a 99-00 for sure... and plug that hole up...
Old Apr 20, 2005 | 04:03 PM
vegaskurt's Avatar
http://www.geocities.com/joeyp....html
The y8 I got was already plugged, I'll see if I can get a pic up later of it. I havent had the time to put it in yet.
Old Apr 20, 2005 | 07:28 PM
Default Re: (vegaskurt)
i figured it out. i was plugging the one hole in the center instead of the four at each injector.
AllmotorGSReg
20
Apr 12, 2013 05:57 PM
Cheefer_EX
Nov 17, 2012 04:28 PM
eg2phosizzle
Feb 23, 2006 09:02 PM
firstgenrex
Oct 9, 2003 02:55 PM
