changing plugs
Old Apr 18, 2005 | 04:00 PM
getnasty's Avatar
Default changing plugs
well im trying to change the plugs in my girls bike and I cant seem to get a socket down in there. what special tool is needed? maybe im just a complete dumbass. but I cant seem to get it. by the way its on a 900RR
Old Apr 18, 2005 | 05:42 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: changing plugs (bottle fed)
I just changed the plugs when I brought my bike out of storage. Drop the spark plug socket down in the spark plug tube. Take about a 4-5" extension and slide down in and connect. It should barely stick out of the spark plug tube. Attach wrench and loosen. Then once loose enough remove wrench and you should have just barely enough room to pull the extension, socket and plug out of the spark plug tube. Repeat for rest of cylinders. I did three on the left side and one on the right. Kind of a pain, but you just have to be patient and take your time.
Old Apr 18, 2005 | 06:12 PM
getnasty's Avatar
Default Re: changing plugs (Mr Hammond)
what size socket did you use? if that works I will try tommorow.thanks! I hope it will work because my frame is in the way but I will try tommorow
Old Apr 18, 2005 | 06:43 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">what size socket did you use? if that works I will try tommorow.thanks! I hope it will work because my frame is in the way but I will try tommorow</TD></TR></TABLE>
A spark plug socket. I mean they come in 5/8" or 13/16". You will want a 5/8", but you want a spark plug socket. You know one that's deepwell and has the rubber ring inside to hold the plug. I hope you are using one of those.
Old Apr 19, 2005 | 06:47 PM
getnasty's Avatar
yeah thanks I got it.. I had to have a special tool for the 900RR. but thanks I apreciate the help
Old Apr 19, 2005 | 08:22 PM
mike5809's Avatar
i had the same problem. i ended up using a swivel socket and an extension after a few minutes of frustrating agravation.
but ur bike should have a tool kit for easier access
Old Apr 20, 2005 | 04:03 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">yeah thanks I got it.. I had to have a special tool for the 900RR. but thanks I apreciate the help </TD></TR></TABLE>
What did you have to end up using?
Old Apr 20, 2005 | 09:27 AM
cbrman's Avatar
I have noticed that alot of spark plug sockets have a thick wall on them and will not fit inside the head. Look for a thin walled spark plug socket.
Same type of problem on my friends rav 4. I could not get the friggen socket down into the head to remove the plugs.
BLKFLSH
Jun 18, 2013 05:16 AM
b20bFourDoorCivicLX
Mar 16, 2012 10:26 PM
KloC 95 EG
28
Feb 2, 2009 12:35 AM
imzjustplayin
Dec 22, 2008 01:01 PM
mntdewred
Sep 25, 2004 07:11 PM
