Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Installing spark plugs made easy
Old 06-09-2013, 06:04 AM
BLKFLSH's Avatar
Default Installing spark plugs made easy
Have you ever installed your spark plugs, then tried to pull the socket out, and it stayed on the plug down in the tube? The craftsman spark plug socket I used before had the rubber insert to hold the plug into the socket. Problem was, it held on to the plug soooo tight, the extension would pull out of the socket, leaving it on the plug inside the tube. I found a tool that makes spark plug install a breeze. It's a Gear Wrench Magnetic spark plug socket, with 6" swivel extension Part #10546. I got the tool from Advance auto parts for $10.49, and it works great even on the rear bank of the V6 engine. The torque wrench is also a good idea, because you don't want the plugs too tight, or too loose (13ftlbs) Picture below
Old 06-09-2013, 07:58 AM
My Name is Nobody
MSchu's Avatar
Default Re: Installing spark plugs made easy
For the last 30 years, I've always used a locking extension on my sockets when doing spark plugs. But it wasn't a mere $10
Old 06-18-2013, 05:16 AM
denialchild45's Avatar
Awesome!
imzjustplayin
12-22-2008 01:01 PM
Lithel
12-09-2008 09:09 AM
poland accord
12-04-2008 07:07 PM
RACEPAK
09-21-2005 04:08 AM
Quick Reply: Installing spark plugs made easy
