bled clutch..still no pressure....
Old Apr 18, 2005 | 03:51 PM
5ltreater's Avatar
Default bled clutch..still no pressure....
ok, 3rd is gone in tranny and alittle while ago i started to loose pressure in clutch peddle..could this be my pressure plate is gone..i mean my clutch peddle goes compl. to the floor and wont come back..wont go in gear...
please help me out here ht members..
Old Apr 18, 2005 | 03:55 PM
nocturnaldragon's Avatar
Default Re: bled clutch..still no pressure.... (5ltreater)
its possible,
Remove the rubber boot on the tranny, check for play everything should be tight. IE the fork should be putting pressure on the piston forcing it back into the cylinder, so if its lose there then your pressure plate is messed up or you have a bent fork. Either way trannys got to come off. if its all tight then its a problem in the hydro system somewhere.
Old Apr 18, 2005 | 04:03 PM
5ltreater's Avatar
thanks
Old Apr 18, 2005 | 04:08 PM
thehatchninja's Avatar
Default Re: (5ltreater)
it's probably not the pp, sounds like a hydraulic problem. a bad clutch master cylinder ruined my 3rd gear too, try master and slave.....then bleed it for 3 days straight. you'll be fine.....except for that 3rd gear
Old Apr 19, 2005 | 12:39 PM
5ltreater's Avatar
Default Re: (thehatchninja)
prob def worth it...ill give it a shot...what will put pressure back in my clutch tho its sittin on the floor
Old Apr 19, 2005 | 12:40 PM
5ltreater's Avatar
need this post back at top//.
Hippslsvtec18
May 21, 2010 10:54 AM
JDM_SOHC
36
May 21, 2007 03:50 PM
HiAssHell
Nov 5, 2005 05:04 PM
93preludes
Aug 14, 2003 05:56 AM
