My compression #'s
Old Apr 18, 2005 | 03:31 PM
RRRex's Avatar
Default My compression #'s
So I did a compression test on my 01 JDM ITR motor just now and these are my numbers. Turned the car over 5 times on each cyl then took a reading. Then repeated the test with a cap full of oil in each cyl. These are my numbers. Thoughts?
So what does this mean?
Cyl#1
Dry - 190
Wet - 240
Cyl#2
Dry - 200
Wet - 240
Cyl#3
Dry - 200
Wet - 230
Cyl#4
Dry - 175
Wet - 200
Old Apr 18, 2005 | 03:36 PM
TypeRlove's Avatar
Default Re: My compression #'s (RRRex)
from reading here, id say you are totally good.
Old Apr 18, 2005 | 03:45 PM
RRRex's Avatar
Default Re: My compression #'s (TypeRlove)
Car dynoed at 180whp on a DynoJet with a short ram and Vibrant headers. Was at the track yesterday and was told I was puffing a bit of smoke. Hence the compression test.
Old Apr 18, 2005 | 05:09 PM
TypeRlove's Avatar
ill add that i am a newB. take a look at a helms manual to find out exactly how much variation is acceptable between the cylinders. there is a helms website, search honda-tech to find it. good luck. btw, i have heard of R's smoking out the exaust, i believe that if it is blue smoke you have a problem. of course, i am no expert.
good luck. 180 whp with the mods you have is very good.
Old Apr 18, 2005 | 05:28 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Watch for Cylinder 4... you might have a problem in that one.
How much oil do you use?
What color was the smoke?
There's also a possibility that your car had some smoke because it was running rich.
Old Apr 18, 2005 | 06:26 PM
totsie7944's Avatar
Default Re: (VashTheStampede)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">Watch for Cylinder 4... you might have a problem in that one.
There's also a possibility that your car had some smoke because it was running rich. </TD></TR></TABLE>
yea cylinder 4 kinda dropped a bit. You idealy want to have even numbers across the board. Its not really what number as long as they all are near the same. Obviously R's have high compression anyway. Might wanna take a look at 4 though.
Old Apr 18, 2005 | 06:32 PM
ek4b18c_r's Avatar
Default Re: (totsie7944)
numbers are ok when i did mine, i was getting around 220-230 dry and they didn't go that much higher with the wet test, but you are fine.
Old Apr 18, 2005 | 08:11 PM
RRRex's Avatar
Default Re: (ek4b18c_r)
I went through about a liter/quart of oil for a full day of lapping. I was running 5W30 which is a bit thin anyway. I just put in Motul 5W40 to see if that helps. People at the track were the ones telling me they saw blue smoke. The oil also went black towards the end of the day which concerns me a little too. I was in the underground tonight and looked at the mirror on the wall and it looked black to me.
There seems to be a big drop on #4 and from my understanding the wet test shouldn't jump 20%+. 5-10% is what we should be looking for, isn't it? The purpose of the oil is to find leaks in the cyl and plug them. No leaks, no change in compression. If there are leaks, then the oil fills them and we see a big increase in pressure. Or at least that's my understanding.
Old Apr 19, 2005 | 01:55 PM
RRRex's Avatar
Default Re: (RRRex)
Would doing a valve adjustment effect compression? In theory it should.
climb_on
Jul 29, 2007 03:40 PM
Boostin_GSR
May 23, 2007 01:12 PM
guero2craze
May 8, 2007 09:15 PM
baboonstyle
Oct 29, 2003 03:53 AM
sCeRaXn
Oct 9, 2002 04:43 PM
