Help...Finish b1b swap...need help on extra problem...
I just finished swapping over my B16 engine into my crx, but for some reason the wheel hub is locking up after I tighten my axle bolt. Why is the hub locking up? Is it a wheel bearing issue or an axle issue? Thanks ahead.
It is a hub issue. There is a dust ring inside the hub. You need to remove these on each side. That should allow the axle to rotate freely. This mod is required when using 90-93 integra axles with a b16a swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">It is a hub issue. There is a dust ring inside the hub. You need to remove these on each side. That should allow the axle to rotate freely. This mod is required when using 90-93 integra axles with a b16a swap.</TD></TR></TABLE>
How does the dust ring look like??? Do you have a picture of the dust ring?
wunPOINTeight
Jun 15, 2021 06:37 PM
CRX7
Nov 20, 2002 12:55 PM
