Do i need a new clutch? Help Please
Old Apr 18, 2005 | 01:20 PM
CrAzyGsR101's Avatar
Default Do i need a new clutch? Help Please
Well this morning I get in my car and headed for school as usual. I rev match to go into 2nd and the gate won’t open, so I try third and fourth they won’t budge either. I let off the gas and then it goes in. This happens the whole way to school. Sometimes it goes in smooth other times it’s a bitch. Trying to rev match into second wont even work I have to ease into it. Then in first gear when I engage and I start to roll of the line it feels like it’s the clutch is stuck and it grinds and you feel the clutch pedal shake a little to. So my question to you guys is what the hell is this time for a new clutch or something else? O and the car is a 99 GSR with 95k miles thanks!
Old Apr 18, 2005 | 01:40 PM
desiromeo812's Avatar
Default Re: Do i need a new clutch? Help Please (CrAzyGsR101)
dude same thing happened to me maan it sucked like a biatch if you kno what i mean but i did order a new clutch cuz people told my it was my pressure plate.. so i needed a whole kit but eventually it started workin jus fine after about a week n a half..... jus try to not force it into gears and shift at hella low rpm's i have a 98 gsr with 84k..... but if you need a excedy clutch lemme kno i got one sittin in my trunk which i dont think i need to put it cuz i dont drive my car rough... good luck with it maan
Old Apr 18, 2005 | 03:24 PM
VINtegra90's Avatar
Default Re: Do i need a new clutch? Help Please (desiromeo812)
well idont know what the problem is but if its the clutch dont wait on it.. you'll be sitting on the side of the road calling ur parents to pick u up. bump ur clutch to the next level and get a lightweight flywheel, that exedy/fidenza **** is cheap.
Old Apr 18, 2005 | 11:29 PM
Thanks for the replies anyone with this same problem?
Old Apr 19, 2005 | 12:48 AM
jspec-integ Ls's Avatar
yup, same here, but fortunately i caught the problem asap. It was actually my clutch disk going out, one of the springs had fallen off the disk, and it was about time for a change anyways. I replaced it w/ a clutchmasters stage 3 w/ act streetlite. I should of went w/ the prolite.
Smokeless
Jun 26, 2019 03:15 PM
ac_attak
Sep 5, 2008 09:53 AM
Nicks95GSR
Mar 26, 2007 10:25 AM
Loveless
Aug 4, 2003 12:19 AM
brucie
Jul 12, 2003 11:23 AM
