teg wit cut springs....
how much does cut springs lower the integ?
i'm still learnin about cars and I dunno how much my car is lowered cause it came with the springs cut.
I just got some eibach lowering springs which I want get installed on wednesday but I want it the same height or close to the height my car is now with the cut springs
Depends on how much of the spring they cut, search on info about eibach springs and you'll find out how much it will lower your car. I personally don't know how much it will lower your car but im sure someone will know
It does really depend on how much they are cut. Cut stock springs are the cheap way to go but it will more than likely ride like booty. espically if you dont cut the stopper. My suggestion is save some money and get springs or coil overs. you will really notice a difference. coil overs are cool cu you can drop raise to the exact height you want. if you change your mind, ok just adjust them.
Markb16a
10
Sep 11, 2006 05:58 AM
