Need help quick
Old Apr 18, 2005 | 11:13 AM
Dino_D's Avatar
Default Need help quick
I just got a b18b and I have it laying on my garage floor. I went to turn it over and it will not move it just makes a light creeking noise. Think its seized.
Old Apr 18, 2005 | 11:34 AM
Dino_D's Avatar
Default Re: Need help quick (Sc2_Dan)
Old Apr 18, 2005 | 11:57 AM
Dino_D's Avatar
Old Apr 18, 2005 | 12:14 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
will it turn over at all? Is there any oil in it? Did it get wet?
Old Apr 18, 2005 | 12:33 PM
Dino_D's Avatar
Default Re: Need help quick (JDM_Ej)
Wont turn. I put like a capful of oil in each cylinder. I bought it from someone on here and I dont think it got wet.
Old Apr 18, 2005 | 12:41 PM
Cuong-nutz's Avatar
don't know how long it's been sitting. Pull the valve cover and see if the valve train is dry or not.
edit: just keep on turning her over by hand and see if the creaking goes away. Can it turn over at all or not?
Old Apr 18, 2005 | 12:44 PM
deSigi's Avatar
Is the transmission housing attached? I'm asking because a buddy of mine had the same problem. It turned out the the pressure plate wasn't bolted on properly and it was rubbing on the inside of the clutch housing and basically dug too much in the housing and was just stuck. It gave us the exact same syptoms as if the engine was seized.
Otherwise I really can't think of anything else. Sometimes having the spark plugs screwed in the head makes it hard to crank over, but I'm assuming you know that considering you knew to put some oil in the cylinders. Besides that I really don't know what to tell you.
Free bump for anyone who might have another idea what the problem might be. Hope your engines not seized.
Old Apr 18, 2005 | 12:50 PM
Dino_D's Avatar
Default Re: Need help quick (deSigi)
Tranny is attached I just bought the motor like 5 days ago. Wont crank. No spark plugs. The oil filter has the date 12-2-03 on it so I am guessin that is how long it has not been in a car. Maybe moisture got into it? It has been garaged and there is a bit of oil under the valve cover.
Old Apr 18, 2005 | 12:54 PM
Cuong-nutz's Avatar
when you got it, did it have spark plugs? if so, moisture could not have had gotten into it. How hard is it to turn over?
Old Apr 18, 2005 | 08:13 PM
Dino_D's Avatar
Default Re: Need help quick (Cuong-nutz)
No plugs came with it. It doesnt turn at all just makes a light creaking noise. I am no wimp and I have a 4 foot breaker bar so.....
Old Apr 19, 2005 | 03:28 PM
Dino_D's Avatar
Took all transmission parts off the black and no go. Its locked up tried jumping the starter,crank pulley belt, strap wrech on the crank pulley. Nothing.
Old Apr 19, 2005 | 03:35 PM
mattssi's Avatar
You can poor all the oil you want down the spark plug hole, but if the motor has been sitting for a long time, you need to oil the rotating assembly. put it on a engine stand and pull the oil pan and put some oil on the bearings. done and done.
Old Apr 19, 2005 | 03:36 PM
Dino_D's Avatar
Default Re: (mattssi)
I did that
firstgenrex
Feb 21, 2010 09:04 PM
burnout289
Jun 16, 2005 07:07 PM
crdcz03
Sep 24, 2004 06:57 AM
